I don't know if it's just me but every time I do a small repair to an appliance the appliance takes offense and commits suicide. Last year I replaced the pump on our front-load washing machine and the drum bearing disintegrated. I recently replaced a movable row of tines in the dishwasher that had corroded away. Two days later the super quiet machine started making loud growling noises. Hoping it was nothing serious, I ignored it. Next day it would not run so I checked the price of a new pump motor for this 13-year-old dishwasher. Just over $130 so I think I'm going to order it. But first I have to get the water out of the machine. Press the CANCEL button and I hear the pump running. I'm having deja-vu all over again.
My wife does not want me to disassemble the dishwasher and have the kitchen torn up for days. I order a new dishwasher (same brand - Kitchenaid) and skip the installation charge as well as the plumbing kit. I have lots of plumbing supplies and can use the power cord from the old machine. Machine arrives and it has a new supply line setup. The old one needed a 3/8" copper line with a compression fitting. The new one needs a 90-degree garden hose fitting to adapt to the 3/8" compression fitting. After the dreaded Home Depot visit I have the parts and the dishwasher is all hooked up.
When I trial fitted the new dishwasher, the handle just barely cleared the silverware drawer next to it. Once the power, water supply and drain lines are connected and routed behind the machine, the dishwasher handle is blocking the silverware drawer.
I decided the easiest fix was to notch the drawer face. A little blue tape and a Silver Sharpie (recent acquisition I didn't know I needed) and I know how big a notch to make.
Now all I have to do is remove the drawer-front. After I remove the 4 screws, it still won't come off. I figure something sticky got in there so I go get my 1969 Shell Steak Knife and try to pop it off. No such luck so I get out the jack hammers and dynamite. Turns out the drawer fronts are stapled on the drawer and then the screws were added over them.
A little work with a coping saw and a drill-mounted sanding drum and I have a notch that matches the Silver Sharpie mark. I probably have a can of stain somewhere that would be a decent match but I choose a no-wait-to-dry solution: brown shoe polish. Even this is overkill because you can't see the notch when it all goes back together. You also can't see the chip in the laminate...
It all goes back together with a little fussing. Drive the staples back into the drawer, get some longer screws to align the holes, hammer the staples back in place and then re-install the short screws. Drawer opens without hitting the dishwasher handle.
