Diesel light truck tooLs
magicrat
If someone is only going to be working on smaller diesel trucks like ford and Dodge 250, 350s. Mostly year 2000 to brand new as it will be at a dealership.....do they still need a lot of sae sockets? I am not a mechanic I'm an hvac guy so please forgive my ignorance....thanks guys in advance.
WittHay
Surrey, BC Canada
You have a good question? If you are working on Ag/HD equipment it seems you need every socket made from 1/4" to 1" drive.
But if you are a apprentice starting at a Dodge/Ford dealership in 2017 do you need any SAE sockets?
wolf_from_wv
WV
Used 9/16", 5/8", 11/16", 15mm, and 13mm on a 1997 F250 with 7.3L diesel over the weekend.
wolf_from_wv
WV
Forgot the 1/4" screwdriver and socket for hose clamps.
I think we used the 10mm more a couple weeks ago. This time was tracking down an oil leak.
magicrat
Thanks.....I was told diesel used all standard but I think they may have been referring to large heavy duty diesels like international......so I guess metric will be fine for now
DetroitDIESEL444
most modern diesels are metrics... internationals, cummins, cats, fords. I see a lot of standard in old 6.9/7.3 idi, dta-360's and mechanical dt-466. Ford 7.8 and 6.6 liters as well as n14 cummins and 855 cummins.
dsimatt
International is so *** backwards it wouldn't surprise me but even they use metric sizes, you could make do with a cheap set of see for the time being.
Moparman390
I just worked for Navistar in the HQ for a while, the company is still a giant Charlie Foxtrot.
crf450x
Fall Branch, TN
99% will be metric on light duty stuff. I actually cant think of anything after ~05 besides battery clamps that is sae. Medium and heavy duty are usually half and half which is ridiculous.
dsimatt
We'll had a brand new truck of theirs in the shop and they still can't make a truck that's not a zip tie and loom clamp cluster **** under the hood, they are bottom of the barrel.
