Junkman
I am having a problem getting the 12 gauge stranded wire under the ground screw on the GFIC receptacle. I was wondering if it would be acceptable to put a spade crimp terminal on the wire, and then put the spade under the screw. I was able to get the wire under and around the screw, however, when I tighten the screw, the wire flattens out, and it looks very sloppy. I gave it a tug, and it didn't move, so I am certain that it is secure. This outlet is in the air conditioning disconnect box, per the code. The receptacle is made with clamps that secure the black and white wires when you tighten the screws.
