Drill bits for stainless steel sheets
signcrafter
I need to drill about 40 holes in some thinner stainless steel sheet. Hole size will be 1/4" or smaller. What is the best drill bit for this? I only need one size so can order a couple of them but just seeing what type I should get. Cutting oil when drilling?
signcrafter
I would use these... you need to drill a pilot 1/8" but then these bits cut a pretty damn near PERFECT hole.
https://www.amazon.com/Blair-Equipment-11090N-Rotabroach-Cutter/dp/B000LQOCRK/ref=sr_1_5?ie=UTF8&qid=1497624580&sr=8-5&keywords=annular+cutter
Hole will be less then 1/4" diameter so just need a drill bit.
How thin of a sheet? Is punching an option?
Not sure the exact size but less then 1/8" thick sheets. Punching would be an option and I do have a Whitney but the sheet is already on the wall so that rules punching out.
mrjaw14
Nashville, TN
Maybe try cobalt drill bits in the size you want plus a pilot hole bit? Stainless takes longer to drill, and wears bits out faster, but a regular bit will do it. Cobalt will have longer life. Another option would be nice HSS bits. Just not the big box **** coated bits
royesses
135° cobalt drill bits. Don't let the drill sit and spin without cutting. Heavy even pressure so the bit is always cutting. A good cutting oil will help.
Roy
T45
Do some homework on the substrate...if the stainless is work hardening or not you may want to use something as noted above cobalt m42 or maybe sometimes HSS m7 like norseman/champion...either usually come in a 135 degree split-point.
Also, unless you need a long-access-bit, I would opt for a machine-screw or mechanic length and skip the jobbers.
larry_g
oregon
Agree here, know the material you are working with. Some stainless machines pretty good and some is a *****. I also second the screw machine length bits. If you need a round hole then a twist drill would not be my first choice.
lg
no neat sig line
mowkep
Stow, Ohio
We use thicker goo made especially for stainless. We get it McMaster Carr. I can't recall the name off hand. Works great though. But it will oxidize regular steel if you don't clean it off right away. Sharp tooling and slow speed
Marctrees
TX/LA border - Toledo Bend
Seems to me a good quality "step bit" would be great.
As said above, decent feed pressure, keep it cutting the whole time.
Other than the hardness, physically simple to sharpen if needed.
But, I am just an occasional metalworker, can't advise further as to lube, etc.
Marc
MJD1
Use a quality brand such as Viking , cobalt bit. Anchor lube, which is a almost paste like cutting fluid works very well.
dr_clyde
Holland, MI
I routinely drill stainless, I work in an food production environment. Everything is stainless sheet.
Twist drills in sheet metal tend to make out of round holes. If you must use a twist drill, use Norseman/CTD drills. Their high molybdenum content makes them well suited for SS. Otherwise a good cobalt drill. Lots of feed pressure, low SFM. Use machinery's handbook for the formula for RPM to get the right SFM for your size.
However, if you need a nice round hole, Hougen makes a set of mini rotobroaches. They work excellent, just center punch and drill.
Best lube I've found is Union Butterfield, followed by Tap Magic. Avoid the dark sulphur oil on SS.
lilredex
Toronto
Made a wavy flavour bar/ heat plate similar to the link, from some scrap SS that may have been a commercial kitchen top at about 16Ga, was pretty tough stuff to bend. Drilled more than 40 holes (1/2") in it with a step drill, with no pilot hole. It was an easy drilling job and the bit was nothing special, just from a pack of three from Canadian Tire ($10). Drilled them all dry too, on the DP.
https://www.amazon.ca/dp/B002DQC6VA/?tag=atomicindus04-20
