Bought a BendPak MD-6XP and have it in the garage, ready to connect the hydraulic line.
Question is, if plumb it up with the factory setup, and I use it for a while and then later need to disconnect the hydraulics from the lift, or from the "power unit", how much of a mess is this going to make?
What about using some high-quality quick disconnects on the hydraulic line? Something like a flush face, dry break coupling rated for 10,000 psi ? Like this:
https://www.hydradynellc.com/products?Filter=11697.snap-tite-71-series-high-pressure-non-spill-push-to-connect/department.hose-fittings/product-type.quick-disconnect-couplings/&gclid=Cj0KEQjwyZjKBRDu--WG9ayT_ZEBEiQApZBFuIy12Nu59VOEqKDd9eYfYS5DLdIGveb-qLDrAj4zCKIaApaa8P8HAQ
Also seen here:
https://www.discounthydraulichose.com/product_p/2htf2-ht2f2.htm
Looking forward to using the lift, just wanting to add flexibility to moving it around and placing the power unit in different parts of the garage as I move it between bays. BUT, not wanting to compromise safety...
Thanks
Also seen here:
Thanks
