Old Spinner ID
Provincial
Near Salem, OR
I picked up a couple of very old spinners many years ago. They have similar knobs on the back, so they could be made by the same company.
The smaller one is made of 3/8" diameter round steel, and the drive end just has a 3/16" cross hole and no square. It is marked with the Herbrand script, but no number. It is about 25 inches long.
The larger one has a 1/2" square drive end and the socket is kept from coming too far up the square by a cross pin. I can find no markings on it at all. Overall it has a rough finish, like it was made from a rough forging and no finishing was done. It is quite long, over 33 inches.
I don't know when they were made, but I suspect it was before 1930. The Herbrand logo came into use in the 1920's.
I wonder if the Herbrand spinner was part of another tool, with an attachment pinned on the end.
The larger spinner appears to be a socket drive tool, but I have no idea who made it, other than the palm rest is of similar pattern to the Herbrand.
Anyone have more information?
r_olson_06
SD
I have one similar to your large one at home. If I remember correctly it is either Blackhawk or Walden. I will look later today.
Sent from my XT1080 using Tapatalk
P
Provincial
Near Salem, OR
Thanks, 3bay, but the spinner knob is perfectly smooth after a trip to the wire wheel.
I think the Herbrand was part of a tool that had a coupling on the end, but without early catalog illustrations, it will be difficult to determine.
Maybe r olsen will find his sample.
r_olson_06
SD
Sorry for the delay. The one I found are similar but no markers.
P
Provincial
Near Salem, OR
The cross-pin on the 1/2" drive that keeps the socket from moving too far up the square appears to be an uncommon design. Does that ring any bells with anyone?
I found a similar spinner to the Herbrand on Ebay. It doesn't have the same knob, but the working end gives me a good idea of the use of the cross pin to attach a working piece. http://www.ebay.com/itm/No-8-Old-Antique-Model-T-A-Flathead-ford-Car-Valve-Lapping-Tool/263039325362?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
P
Provincial
Near Salem, OR
Yes, the knob design indicates early tools. The Herbrand logo dates to 1921, so that one can't be older than that. I'm not sure when 1/2" drive started, but the other spinner can't be very long after it originated, due to the cross pin design.
I suppose it isn't worth much effort to search, but I have been stumbling over these two cranks for years and finally decided to do some research.
Well, it's fun to try and figure it out. I have a problem in that I like to see what brand everything is/was, especially when I go anywhere with old used tools for sale.
Most early fixed handle tools were marked. Like R Olson mentioned, Walden, Blackhawk, Mossberg, etc.. If it's not marked then it's a real mystery.
You get into the early Duro made stuff and no name on some of it, but a speeder should have a ball and stops on the square.
