Loose Ctrl
I am building a 12x16 workshop. It's going to be sealed pretty tight. I will be working on motorcycles, pieces of equipment with small engines, etc.. At times, I will be working with the door closed.
I have experienced a fuel fire before when working on engines. To reduce the fire risk, I have considered buying a flammables locker. If you haven't seen the prices of these things, they are expensive. Worth it in some circumstances. I think it's overkill for my little set up.
This is what I will keep in it.
1x 5-gallon gasoline
6x 2.5-gallon gasoline
4x 5-gallon kerosene
1x 1-gallon 2 stroke mix
1x 1-gallon paint thinner
2x 1-gallon denatured alcohol
1x 5-gallonn carb and parts cleaner
And other various small containers of solvent based fluids, spray cans of various paints, cleaners,etc..
I thought I would build a sealed wood cabinet 4 feet tall, 4 feet wide, 2 feet deep, with double doors. I would raise it one foot off the ground, and mount it to the outside of my shop out of the sun. I would put in ground supports so the building wall wouldn't take all of the weight of the loaded cabinet. The wall would keep it stable and from tipping over. I will install steel mesh in the floor and use it for shelves to allow the vapors to vent out the bottom.
What ideas do you guys have? Any reasons why this would be a bad idea? Any ideas to improve upon this idea? I know 4H x 4W x 2D will be tight for everything that I have, but most of the containers will be empty. I can store them in my carport.
