Need electrical help!
e-tek
Saskatoon, SK
I have a three-way switch in my attached garage that I would like to convert to a plug. It controls the ceiling lights, sames as two other switches. It has 2 wires coming up from the bottom (w-b) and three coming from the top, going to the lights (w-b-r).
I removed the switch, which had one black, one white and the red attached andd attached a plug with the white wires on one side and the blacks on the other - which is all good - but it's still switched. I tried the red wire on one side and got sparks. Attached to the other - none of the switches work, all the lights stay on.
What am I doing wrong?:headscrat
aandpdan
In between MA and PA
Do you know if the 2 wires (white/black) are the feed or do they go to your lights (load)?
The red/white/black set connects to the other switch. You'll need to replace that switch with a single pole switch.
How was the old switch wired?
I can think of how to do this but need to know what you're dealing with.
Schrodingers Cat
are you saying 3 switches total?
if so that is a 4-way switch with 2 3-ways
the circuit could be wired in a few ways, ie, where the load is run to
aandpdan
Try this, you don't need the red wire, just cap it off.
If it doesn't look right, let me know how it's wired.
E
e-tek
Saskatoon, SK
It's like the third sample in cat's schematic. Now whow me how you would wire a plug into that system. Juding by that and aanpdan's, I shouldn't have white wire attached to the plug...
Schrodingers Cat
if what you are asking is can the 3-way to the far right be replace by a recept that is not switch, no
you are short a wire...
even if you removed the right switch and put it in the center and tied the light to that switches output, you would only have a wire from the center to the right...so all V in the center is still switched...
you need a wire from the left to the center also
The Motts
If you can determine which switch box has constant power run to it, hopefully one of the 3-way boxes, you can install a combination device in that box. It will have a 3-way switch and a single receptacle on a single yoke. Of course if the box you want the receptacle in does not have constant power, this won't work.
