The Harbor Freight PASS/FAIL Thread...
VC455
NH
Thanks for the reply. For some reson I can't do a search on my tablet when I try the screen opens the keyboard and closes it. Happens on a few sites.
Is that the hf model you posted.
I expierence the the same frustrating phenomenon, when using the Search function.
' For some reson I can't do a search on my tablet when I try the screen opens the keyboard and closes it. '
I thought it was just me 'operator /operator's equipment, error',
gave up and miss the valuable resource.
mikalos
Right angle screwdriver - 92630 - while i can't rate this yet, i noticed when opening the package that it has an un-advertised feature.
On the opposite side of the handle from where you put the 1/4" hex bits, it has a 1/4" square socket drive post, hidden under a knurled plastic knob that pulls right off.
That will come in very handy for a lot of the small, awkward work i do in spaces that are too small.
Thank you Harbor Freight!
emeraldcoupe
spring hill, florida
I have two of these, they work great. I actually just used it again Friday.
nolan7120
Chicago Burbs
I assembled the 5 drawer tool cart today and ran into some assembly issues. The holes for the side supports don't line up. I had to drill them out at the bottom a little bit in order to be able to bolt the parts together. Also, once I had the main body set in the cart (before attaching the body to the 4 legs), the holes at the front didn't completely line up. I had to use a shim in order to get things to line up. Finally, this is minor but the step to attach the side bar should've been after the step to attach the cross-brackets.
Outside of these assembly issues, the cart seems sturdy and everything functions well. We'll see how it holds up over time.
If you don't mind modifying two pieces of the cart while assembling it (assuming you run into this issue), then the cart gets a pass. If you're the kind of person that thinks no custom-fitting should have to be made during assembly, then it's a fail.
Kent_B
MI
I bought myself the 4 drawer cart for Father's day and ran into the exact same issues that nolan7120 did. I modified mine with a rotary tool and a carbide cutter. I really didn't expect much different from HF. I did assemble completely before tightening any fasteners. Despite that, after assembly my cart seems rigid. I like the thing and I'll give it a pass.
nolan7120
Chicago Burbs
Did you assemble it loose or tighten nuts/bolt as you went?
The only parts I tightened all the way down (instead of waiting until the end) were the casters. That has no effect on the side supports. Everything else was assembled finger tight according to the directions and then tightened at the end once all the parts were put together.
Tp2177
Had a little problem with my 5 drawer cart getting the holes lined up but finally did without having to drill or modify any holes. Took around 2.5 hours total doing it by myself.
revrnd
20 Ton shop press, #60603 - PASS
After almost 20 years with a 12 ton press, I upgraded to the new, bolted together 20 ton press. It is a big improvement over the previous orange version. I added a few upgrades to mine, including a winch. I highly recommend it. Oh, there are two versions of the 20 ton press. The #60603 is the one I have.
What is the thickness of the steel channel? How does the construction compare to an 'industrial' version?
Mechanico
Has anyone tried one of these Cen-Tech item #94181 Wire Tracers?
I could use a wire tracer now and then. Sometimes continuity test just don't get the job done because you may not have a place to actually test for continuity that you can get too without taking half the vehicle apart.
Tp2177
Got the wide crown pneumatic stapler today and so far it's a pass. Paid $20 with tax. As long as it holds up long enough to help me finish my screened in porch I'm happy. Any thing else is a bonus.
Tp2177
I am thinking about going back and getting one of the finishing nailers to put the outside trim on for the porch. Will update with results when I do
6PTsocket
How did you determine it was inaccurate? Calibration shop?
Torque wrenches have been consistently rated PASS, very accurate and consistent, just curious why your experience might be so different.
A friend bought one. I found the adjustment like turning old plumbing pipe. They are known to click weakly on low settings. They are what I would expect for 10 bucks. Whether they are accurate or not, they are so crudely made I want no part of them. My Danaher made Husky and ADT are far better made. Danaher made for everybody, including SK. Same guts, plastic or metal handle. They were also many times the HF price. As far as consistency, there never was any at HF. If I need a torque wrench for a critical tightening job, I am not going to buy the cheapest torqe wrench on the market. I would have to get a calibration check to trust it. For what that costs, I could but a wrench I can trust. There will always be a market for the cheapest stuff you can find, whether it is any good or not.
cspcrx
Phoenix, AZ
3 gal 100 psi pancake air compressor. We picked it up for a room project, wainscoting from scratch and built in wall unit. Using it with a bosh 18 gauge brad nailer. Served us very well with hours of use. Picked it up on sale for around $50 if I recall correctly. Great buy.
Easy_Rider
I have a framing nailer and a finishing nailer that I purchased from HF a few years back. I haven't had any issues with them. I put a drop of oil in each time before I use it.
Tp2177
Thanks for the info! That's very good to hear!
jwsia
Land of political corruption & Govt incompetence
trekgod3
Jupiter, Florida
Going on Monday to pick up a new floor jack to replace my Sears 1.5 ton. the jack is going to be used in my shop on my Tundra, the wardens Highlander and what ever else I drag home. Wanting more speed and higher lift than my old jack. Is the Dayton worth the extra hundo? THank you for your opinions.
https://www.harborfreight.com/autom...vy-duty-floor-jack-with-rapid-pump-61282.html
https://www.harborfreight.com/autom...sional-steel-floor-jack-super-duty-63183.html
I have the 3 ton low profile and the steel crossbeam. It's been great so far. I did buy the extended warranty, though.
https://www.harborfreight.com/3-ton-low-profile-steel-heavy-duty-floor-jack-with-rapid-pump-61253.html
And
https://www.harborfreight.com/steel-floor-jack-cross-beam-60762.html
Doesn't look like the crossbeam will fit the Daytona. It's very handy.
jon72vega
Niles Michigan
jwsia,
I have the Daytona jack, and also have a 2-1/2 ton Arcan from Costco.
I like the Daytona better..... Sturdier, pumps up easier, and feels more stable under load.
It also rolls around easily when getting it out or putting it away.
woodturner9
Indiana(ish)
Oh, I have never heard anyone say that before, and have not had that experience. Apparently not a common issue, or perhaps the directions were not read and the tool is not being used as designed.
I'm curious if you realize who makes the HF?
Agreed, the quality of the torque wrench needs to be sufficient - and price is no indication of quality, sadly. Also agree that ALL click type torque wrenches need to be calibrated initially and regularly, which is why many find click type wrenches are impractical for home use. The calibration certification on the HF is only a little better than the Husky, not enough to prove the HF is that much better than the Husky.
Beam type torque wrenches are better for nearly all applications, since they don't go out of calibration and are very repeatable and accurate.
HF also sells a digital torque gauge that is at least 10x more accurate than a click torque wrench, and is an even better option for more critical work like engine building.
Easy_Rider
Yesterday, my wife and I went to harbor freight. I Picked up a badlands 3500 winch for my atv. My wife found a 25 percent off coupon. It saved a ton. It's on the harborfreight mobile page. Saved me 35$ Which paid for a 2 year warranty.
Good through 7/23/17
Coupon code is:
22799653
It's also "current" listed on the home page.
Easy_Rider
HF sells a heat gun that is pretty good. I have had it for about 2 years now. Mainly I use it for heat shrink tubing on wiring projects. It has always worked for me and I have no complaints about it.
cheechi
Triad, NC
^ second that. I have several brands, HF is among the best in terms of cost effectiveness, even though they aren't the best blades you don't get double the cuts for double the cost with others.
ndr1968
Oklahoma
Just stick a pin or needle into the wire you want to test. cover the hole with electrician's tape afterwards if the area the wire is in is exposed to the elements.
joop1987
Does anyone have any experience with any of their Drill Presses?
I got their 8" model and it stops rotating when you apply too much pressure with a large bit. It's fine for small holes. You can change the gear ratio but it doesn't help that much. I'm sure their other models have a more powerful motor.
Tp2177
Got the 63156 18 gauge stapler/nailed combo today. Will post results when I get to the point of needing it for finishing my screened in porch.
619DioFan
San Diego , Ca.
I have one and it works great. use it with a HF pancake compressor. FYI they say the shortest staple it shoots is a 5/8 but I have used 1/2 inch long staples with mine for thinner materials.
Tp2177
Thanks! Plan on using it with my quiet tech kobalt compressor. Really been enjoying that compressor so far.
cheechi
Triad, NC
that stapler/nailer combo gun is a great stapler. It's a better stapler than their standalone air stapler that uses the same staples.
I haven't used it as a brad nailer as the hammer is staple shaped, and you can put a staple-wide gouge if you use it with brads. The separate brad nailer is good too so if you need brads I would go for that.
Between the 18ga stapler/brad combo, an 18ga brad nailer, and the 20ga (T50) stapler I don't have much issue using any of them anytime I have needed them.
Tp2177
Yeah they are so cheap if I ever need just a stand alone finishing nailer I could probably just get one of them too lol. So far got 2 for around 3/4 of the price of one at lowes.
