Eastwood's Master Blaster- Pressure and Soda Blaster
The new Eastwood Dual Blaster is the best of both worlds. You can now select and combine media to suit the job.
•Switch between soda and abrasive in seconds or mix at an infinite ratio between the two medias.
•The exclusive mixing valve allows on the fly mixing or selection between the two abrasives and allows you to cut blasting times in half.
•Use soda media to remove coatings on delicate substrates such as fiberglass, chrome, stainless, etc
•Blast through heavy scale, rust or multiple coatings by quickly switching to abrasives such as crushed glass, glass bead, aluminum oxide, etc .
•This machine is a must for the serious home hobbyist.
