PVC Ball Valve Wrench
manwithtools
Lebanon, TN
For a guy with a bunch of tools, I didn't have the right one for these ball valves in my pool plumbing. They have become increasingly hard to turn over the years and I did not want to break them with alligator pliers or such.
So, 20 minutes or so on the CNC mill with some scrap aluminum tube and a piece of 3/8" shaft that was laying around, we have a "Ball valve wrench".
Handle slides in case you need extra leverage.
Provincial
Near Salem, OR
I did the same thing out of PVC pipe, a tee, and a coupling. I glued pipe into the coupling and cut it off flush before cutting the slots. I glued a piece of pipe into the other end of the coupling for an extension (these valves are buried underground) so I don't have to get down on the ground. I put short stubs in the branches of the tee for leverage.
On one I made for my son-in-law, I left off the stubs in the tee because he is so strong I was afraid he would break the handles off the valves!
L5wolvesf
Northern AZ
Picture please
cherrybomb
Near Madison Wi.
As a homeowner, I appreciate you putting on your thinking cap and coming up with a solution.It was a neat idea.I'm glad you showed all of us.For me anyway,it's always fun to think,plan and produce.Good Job.
Provincial
Near Salem, OR
Here are some photos of my PVC wrenches. The first one is a tool I made to operate my manual locking hubs on my Ford F-250. I cut the slots with a circular saw and filed the radius with a chain saw file. This was a quick and dirty to see if it would work, and it worked so well that I haven't built a prettier one.
The next three photos are of a water shutoff wrench I made for underground valves. The gray is PVC Schedule 40 conduit, which is really the same as PVC water pipe. All the parts are 1-1/4 inch size. I used the coupling and filler pipe to make the working end stronger, and give it a larger contact area on the valve handle.
I made one by using a 3/8" end mill to make a nice slot. I have also made these by drilling a 3/8" cross hole and cutting the slots down to the hole with a hacksaw, leaving a slot with a radiused end. The drill/hacksaw method is nice because it only requires simple tools.
rick53
Thanks for coming up with a great idea.Being on a irrigation ditch in Southern Oregon i have many 1 1/2" ball valves in the ground around my property for wherever i pump water.As you know they get pretty hard over time to turn and i have broken a few over the years using channel locks.Plan on making one today.Thank you
slip knot
Texas gulf coast
The chlorine has swelled the valves. they will eventually break. I changed mine out for chemtrol threaded collar valves. they stick too but at least they can be replaced without tearing everything out and starting over.
