Coolant tester
bmwpower
These things any good?
Fedwrench
Valley of the sun
It depends on what type of coolant you're using them on. For freeze protection it's ok. However, it won't show ph or electrolysis. Dip strips, although, not as cheap do a better job. A refractometer is another option.
Toolhorder
Montana
Ha! beat you to it!:bounce:
bmxr4life87
Bixby Oklahoma
yeah i prefer the strips we use them at work tells you the freeze point the ph and something else then i prefer the refractometer type
Toolhorder
Montana
One disadvantage to those strips is the shelf life. They don't have a long shelf life. I bought a small bottle with the strips and in a yr. they were expired and wouldn't work.
Stick
Alaska
Don't forget you can check the state of the additives in the coolant using a multimeter. Negative lead to batt negative, and positive lead in the coolant with engine running. Should be under 0.5V DC, or the additive package is probably bad.
Toolhorder
Montana
Cost and source for the strips?
Got mine from Matco truck. Can't remember the cost. Under $10 I think. In a shop the strips are great because you can staple them to the RO and the customer can actually see the strip's color so they feel more like you're not trying to upsale them.
vc-onthepc
maryland
strips are good but if you arent doing a ton of coolant checking use a refractometer....strips have a use by date on them .....i ALWAYS USED TO THROW THEM AWAY BEFORE EMPTYING THE CONTAINER !!!FOR BEING OUT OF DATE
