New House - Not too happy with the steps and walkway
beetlespin
New House - Not too happy with the steps and walkway. All the house in the development have the same issues.
Any idea what I can do to make this look better?
D45
NW INDIANA
New subdivision, contractor doesn't care and throws up as many houses as he can, as fast a he can.............so common and typical
Are you talking about the discoloration?
rockettgpw
Sunshine Coast Qld down under
The rises and the runs (step height and depth) look all wrong for a main access. as DadsEH says the steps are too narrow and will likely lead to someone busting an ankle or tail bone from slipping off the edge There's not enough platform area to land on when coming off the verandah. As it is a new house, check on your local ordnances and see if the builder has to replace them. My council is red hot on stairs being correct. I would sort out the safety issue before the appearance issue.
As for appearance, you could could paint them with paving paint with a non slip grit additive, Tile them, or clad them with timber. Could you plant shrubs beside to hide them a bit?
jimreed2160
Tallahassee FL
No insult intended, but I think you are trying to make a silk purse out of a sow's ear. Those look like inexpensive prefab steps that are inadequate. I would leave them alone and save my money for a replacement. It should be wider and the rise distance between steps should be uniform. And don't forget the handrails. A proper job will be in the 1-3k range and that is why the builder did the bare minimum.
jdsac
If it's a new house, it's on the builder to replace them. It's a code issue,
rise/ run . Don't let them wiggle out of it. Surprised the inspector didn't catch it on the final.
jd_1138
NE Ohio
Yep, that's a code violation in most jurisdictions (fall/trip hazard). Someone could get seriously hurt (especially an older person).
If someone will take responsibility, they can send someone out to break that out and re-pour or add some nice wooden steps with side rails. Then you can stain or paint the steps or just seal them.
ard
Sierra Foothills... California
From that photo (without any scale!!) I cannot see how people are declaring a 'code violation'... crazy
You need 36" coming out the door- then he has two steps, of unknown rise and run- then a 'landing' that is continuous (or co-planar) with the walkway on out.
What 'code' violation are people seeing?
buddyboy
sue the builder use the money to put in proper staircase, nothing less than the best
Tejay
Appears that the upper concrete was poured after but no thought into the run of the step below. The run may have been fine when it was poured- 9-10 "( legal) but when the upper portion was done it made the step too narrow. Who knows without a tape measure showing. Perhaps he isn't happy with the different colours of the concrete.
joes169
WI
You beat me to it, I can't see any clear violation either, the risers appear to be about 7" or less, and the treads about 10-11", at least. Some people must work off different codes than 99% of the country. From the small picture, it appears the front porch is ~4' off of the city sidewalk, not sure what else can be done. Also, I'd be highly surprised if the steps aren't drown in on one of the elevations on the blueprint.
The only possible code violation I can potentially see is "IF" the local jurisdiction requires a handrail on steps with more than 20" of rise, but even that has to be awfully close........
joes169
WI
I find that to be highly unlikely. I'm willing to bet the upper stoop was poured long before the steps.
On another note, the only thing that really sticks out to me (other than the obvious discoloring of the steps) is why on Earth the concrete guys that poured the stoop didn't use a vertical jointer on the face of the stoop at the control joint. Just allowing it to crack all willy-nilly is not very thought out IMPO.
Hilltopmasonry
I agree i dont see a code violation issues since the the stairs appear to be the right dimensions....hard to tell from a picture
If the op is complaining about the staining then it appears that they covered up the concrete with plastic after the pour possibly to protect from rain or hot weather? Alot of times the discoloration goes away and there is also alot of products you can use as well to fix that
Hilltopmasonry
I agree i dont see a code violation issues since the the stairs appear to be the right dimensions....hard to tell from a picture though
kbs2244
Local codes vary.
Check what yours says.
If it is out of code, and neighborhood wide, it is time to get a lawyer.
chaosracing
Kutztown, Pa
Without having a tape measure shown in the pics, there is no way to know what the dimensions are. They appear to be correct though.
OP.....what are your issues? Discoloration? Staining? No hand rails? Until its stated, everyones input really will not matter much.
Did you accept the house as the step are, then decide there is something you do not like? You should have done a punch list/repair list prior to accepting the house and signing for it. Now it might be to late. Since its not failing and I am sure they are legal, there may not be any recourse.
If its the staining issue why not get a pressure washer and try cleaning them? Have you talked to the GC at all about it? If so what was his response?
rayra
Escaped from Los Angeles
I'll bet those are not within code spec, particularly for a main entrance. And that you can compel the builder to tear them out and replace them.
But it isn't a hard or expensive job to do yourself, if you already signed off on everything.
VintageVeloce
Am I the only one seeing the strange optical illusion with this photo of these steps? Especially if you cover the right side of the picture? You look at it right and the rise and run swap...
Sent from my MotoG3 using Tapatalk
jd_1138
NE Ohio
After looking on a better screen, it looks ok. But I'd install handrails for safety.
Mikeske
Washington State
If the original poster bought the house before it was built, why did he not reject the stairs from the start? If he bought after the home was built, why did he sign the dotted line?
I am sorry if I am a bit rough but when something is not to your standards you can request that it be bought up to your standards before you sign on the dotted line, after the fact you bought it and if that is the issue for you get out the 6 pound hammer and have at it. Then build it the way you want.
Miss the Pontiacs
Saskatchewan Canada
Why don't you put these steps on Kijiji cheap or even free. It is amazing what people will buy The new owner can haul this set away with a tow truck.
Then have a set poured that step down in a curved 180 degree or half circle. This will give better access and the top platform will give better street appeal. Or do the same with treated, cedar or a trex type material. You can heat Trex an bend it, although you might need more of an arc than a half circle. Would look pretty cool but more costly.
beetlespin
Steps are code. Township is **** about things like this.
What I do not like is the discoloration/stain on the steps. They have been power washed twice already.
We close on the house tomorrow and will ask for compensation, just needed some ideas and hopefully cost on what we should ask for.
D45
NW INDIANA
Looks like a somewhat fresh pour..........how long ago was it poured?
Powerwashed?..........twice?..........already?
joes169
WI
It looks like they had a fair amount of calcium chloride (accelerant) in the concrete so they didn't have to wait around. It will slowly get better as it weathers, but it could take years to be acceptable to you.........
ard
Ah, the OP is back...good.
1. STAIRS ARE TO CODE. So that isnt an issue
2. NO railing is needed, there is simply not enough rise for it to be an issue. (Im a risk taker- give me a deck under 24" and I will NOT put a railing on it to ruing the aesthetics)
3. I wonder if a blast will change the look, make it more uniform?
4. You cannot 'resurface' this without major issues: you would need to do, the whole porch, each step, the landing out to 36 inches, then taper to the walkway. As I recall the tolerances are 1/4" so even thin tile will render a 'code compliant' set of steps to be out of compliance unless EVERY step surface is re-surfaced.
Id ask for $500 to repour. See what they say- settle for 250. They will, or course, tell you that there is a guarantee, and they WILL fix it. And IF you agree, it will be a year and they will ultimately say 'it is fine, within our standards'. Only way you should accept is if they put in writing 'steps will be cleaned or replaced so as to match the porch slab in color and uniformity of appearance'. Something like that
sqznby
Coastal NC
Everyone's jumping to conclusions about codes, rise and run and what not and all it had to with was with the color, hahaha.
Well, I'm glad that's all it was.
Compensation though, I doubt they'll compensate, its a fresh pour. I believe it has been mentioned, you need to give it time to cure.
ChevyEFI
Phoenix, AZ
I vote a mod go in and swap the pic from post 9 with the OP pic., so others can be astonished at his pickiness. :D
Modern fisheye lens camera / phone. :/
toolmiser
La Crosse, WI
Time will make the color just right. What you need is a couple smashed pumpkins or eggs to speed up the process.
joseywales
Southeastern, PA
quit looking at them
There's your winner. Focusing on it, makes it worse.
However, I don't think I could live with what appears to be a short run on the first step off the porch. The lip off the porch, over that top step...I don't like that. I could see kids missing the edge of that first step.
We are getting bids on replacing our outside steps. I went to various hardscape suppliers, to check different tread depths (runs), etc., on display they had built. It's amazing how the body acquires muscle memory on the steps in our homes, etc., and any step that is off can be an issue.
Vintage Veloce
San Diego
nolimits76
Oklahoma
That picture has optical illusions going on. Like others, when I first looked, it appeared you had steps out of whack, but I think your steps are only the upper two. I think the lower part is actually the sidewalk with a joint.
Amazingly, the discoloration drives you nuts. The crack in the porch slab would be the thing that bothered me.
Not sure you can do much except try to let it cure and then acid wash it and neutralize it. I'd probably squeak to the contractor if it bothers you that much, and he will probably do something to make it right. Personally I'd try to get the steps and your porch deck color stained, which most people consider an upgrade.
beetlespin
Thanks everyone for your comments. We close on the house today and it will be on the punch list. I think the only real solution is to not only redo the steps, but as one poster mentioned the crack in the porch using a reputable mason. Although I have seen even reputable mason's work develop cracks, just never seen such horrible staining. What is odd is the pad for the side garage door is perfect.
