Uses for a rotary vane vacuum pump?
danbuff
Western NY
I picked up a nice unused Gast 1022 rotary vane vacuum pump years ago, and I am not sure what I might use it for.
Looked good on the flea market table and the price was right. :)
I will never use for vacuum press and thought I could use for AC work, but it doesn't pull low enough vacuum. (26.5 in-Hg).
I do some woodworking, car repairs, home machine shop work.
Its 3/4HP.
Any ideas for its use in a home shop environment?
Thanks for your inputs.
Dan
PCustoms
VT
Vacuum hold down table for your mill.
I have one, pretty sure the same model. Was setup for a fresh air supply originally. I couldn't stand breathing in the full face mask, so now I use it for vacuum bagging composites.
Davefr
OR
That was my initial thought.. But thought I'd ask the crowd of knowledge first.
Tough sell. No demand and lots of them out there. Expensive to ship. Just save it for a potential future project. (like woodworking veneering or vacuum clamping)
mbshop
visalia ca
Umm, that can be used for ac work. Just need to leave it on a bit longer. 45 minutes should be just fine.
wildbill23c
Idaho
I thought one needs ~ 29 in-Hg for AC work..
Obviously I dont know much about vacuum pumps..
You mentioned ~25in-hg earlier. That could mean a leak somewhere, so may not have been the fault of the vacuum pump, just either wasn't left running long enough, or there was a leak in that AC system. ~29in-hg is the max, but also depends on temperature and your location (elevation).
D
danbuff
Western NY
The maximum vacuum for the pump I have is 26.5 in-Hg.
I was saying that from I read that is not sufficient vacuum for effective AC work.. Wont effectively 'boil' the moisture out.
Firebrick43
West central Indiana
Vacuum bagging veneer and laminated woodworking projects. Make plywood cabinet doors and sheath in epoxy/fiberglass for a smooth and moisture proof doors?
mbshop
visalia ca
In the good old days we would be glad to have that much vac. Moisture will boil off if vac is left on long enough. Having done tons of ac work with older pumps we just didn't have moisture issues in hawaii. But if your not comfortable with that and need it for ac then sell it and get a "proper" pump.
Davefr
OR
Not true. You need to pull below 500 microns for modern HVAC systems. That's 29.9+ in. hg.
The only possible workaround is to use the triple evac. method where you introduce dry nitrogen between each of three evac. cycles. The nitrogen will absorb and sweep away residual moisture. However if the pump cant even get to 29 I wouldn't even try this method.
SantaAna12
Now's your chance to start making stuff with carbon fibre..
Interesting thought. A friend of mine has been learning the ropes and his last piece impressed the hell out of me. He's capable, but his retractible bowsprit skills I do admire.
Ditch
Paradise Ca.
joel63
Central FL
Warrenator
Newberg, OR
Build yourself a pneumatic tube delivery system like they have in bank drive-through windows. Goes from the kitchen to the garage. You will be limited to tubular foods though, like burritos, sub sandwiches, bar shaped donuts, etc.
