Here is my restored 2" Prentiss swivel base. I was unsure as to whether to restore it or just clean it but as I took it apart restoration was the only option.
This is close to the original color. Vise is very tight and smooth. Swivel base is really cool.
Yes, it pulls up. It is spring loaded. I've dismantled these in the past but I cannot figure out how to take this teeny tiny spring loaded base clamp apart, so I oiled it up and left it.Joe
That is a very nice looking little vise and great restoration job too. It seems that the vise also came with bonus ring and watch too
How does the swivel mechanism work? Just looking the swivel mechanism and going on a limb, it almost looks like one pulls up the swivel "pin" and rotate the vise and drop the "pin" to lock it and it might even be spring loaded. Is this even close? Whatever way it works, it is cool and different!
007
Well, Wilton makes the 1780 8" wide jaw combo Tradesman vise.
And I have seen a "traditional" machined slide 8" combo vise recently, maybe it was a Yost?
Joe, Here are a few colors for you to look at. First is what your vise would look like naked. Second is one with an old repaint showing remnants of the light green which I am not sure is true color or faded over time . I painted it hunter green with a satin clear coat. Last is a combination of the light green and hunter green.
As always, your vise and your choice of color. Post a picture of which ever way you go.
Here are a couple of pics from my 7" Prentiss. Exact same design except that on the little one the holes don't go all the way through the base.
Much thanks for the pictures; great looking vises..
I'm not a total purist on vises (yet) so I am not opposed to picking a color of my choice, and I have on a few others. I figured I'd go with something close to the original color on this one if I can find something easily off the shelf. I like the looks of the lighter almost olive color green.
Best
Rob
Nice job on the Reed !
Joe Friday, The color on that Reed above is more of the true color of my Parker taken with a crummy camera.
Anyone have an idea what the original color of this may have been? It appears to have been along the line of a hunter green..?
Joefriday, I used Krylon Italian Olive Satin paint on my Parker.
CLIP
I then spent almost 2 hours today beating the pins out of a 2-pin Wilton 350S. Neither hole was anywhere close to lining up with the other; I had to make a custom punch tool from an allen wrench to drive the pins out. I used the first pin to drive out the second; being that the pins are mild steel I had to drive the second pin the opposite direction back into the nut, and then use a very small file to remove the mushrooming on the first pin before I could drive it back out the other side. I yelled and swore a whole lot. KMScott - maybe you can weigh in here and explain something that I don't understand....but, this seems like an absolutely asinine design to me. The holes look like they were hand drilled at completely different angles, unlike the single pin designs.
I have yet to get the end piece off....it is soaking in some penetrating oil. It very much looks like it was forcefully hammered into the body as I see small hammer marks post machining, under the factory paint. I know this part was friction fit, but it is really on there, and the vise is extremely clean. I wouldn't expect this kind of resistance with no rust or build up.
CLIP
rusty65 If those jaws have 3" C-C there is a good chance KMScott is making them as we speak.
I doubt I will ever buy another Wilton again. I've rarely had issues like this outside of salt-belt automotive projects.
Hi
Does anyone know what is the jaw width of a Prentiss No. 183? The seller seems to imply it is 8" ("PRENTISS 8" VISE N.183 ON STAND ") ! And since the seller also states that “IT OPENS 9" " by 8" the he does not seem to be referring to the jaw opening (like some do and which personally always bugs me).
But from the sketchy info that I have found it seems 183 might have 6" jaws (which based on the photo it makes more sense) and might weighs around 170lb and which would be too light for an 8" Prentiss.
By the way there must have been a fire sale on blue spray cans as not only the ENTIRE vise including the handle as well as even the screw (well minus the red lipstick jaw inserts, must be a female Prentiss species) as well as several other pieces of equipment in the background are drenched in blue paint
(see photo).
Thx
Hi All
Has anyone seen a bullet type vise like this before? It looks funky and interesting specially since it has a hand wheel as opposed the standard arm. It also seems to have a pull up pin swivel mechanism (like the Prentiss that joe.striper recently posted)
The only markings on it are "PA APPL'D FOR" which might stand for "Patent Applied For"
007
eddieK
Serious eye candy. Nicely done!
Did the original jaw insert have a chamfer where the parts met?
akasrick
Never seen one like that! You're right, that pin looks very Prentiss along with the shape of the jaws and front of dynamic
!Hi All
007
Hi All
007
Anybody have an idea what this might be?
FMC:
Thanks for the lead. I think you are right.
Joe:
That little guy is a jewel! Great work. It deserves a top shelf display space.
Looks like a Prentiss to me as well, but I suspect the round handle may have been added sometime during its 100 year life![]()
Thanks Shift. I have located a fixed base version that I'm getting soon. I know Rev Scott has the 2" swivel jaw version. I may have to break into his shop to get it though...
