Between 705 & 1200 SQ/FT ZMotorsports Home and 50x60x16 Shop/RV Garage
shortykorte
Tallahassee, Fl
Ha! A great mind and I think a like. Scary. 653c9a0b570c8434a4bd6536c5e2c9ae.jpg
As you can see, I need handles so I looked at Global and found some replacements. Thanks.
On the lathe, I like the use of panel box to hold a magnetic clip for drawings. I'm new to all these controllers, VFRs, etc so have to ask want is that in the panel box.
Z
zmotorsports
Northern Utah
Hey, nice cabinets there Shorty.:thumbup: Ours look very similar and especially the way they are arranged.
As for the NEMA enclosure above my lathe, that is where my VFD (Variable Frequency Drive) for the lathe is mounted. I ordered my lathe in 3 phase and by using a VFD you can take single phase and convert it to 3 phase in small HP configurations. I prefer to have the lathe ran off of 3 phase and this was a nice option to power it as I really didn't want to mess with a phase converter.
Thanks again for posting and following along Shorty.
Mike
Z
zmotorsports
Northern Utah
Well I started my Steevo style workbenches today.
Started off with some mockup and measuring. I'm 6'2" (and shrinking slightly) and my son is 6'4" so we are shooting for a 39.5"-40" height to top of work surface.
Finally getting to use some of my equipment and start fabricating.
Thanks for looking.
Mike
shortykorte
Tallahassee, Fl
Seeing that saw (and other tools) , I'll be stopping to do some fab work. At 6-6 can you make one bench 42". Lol.
Z
zmotorsports
Northern Utah
Benches are started.
One end piece clamped together for welding.
Two end pieces mocked into position around one box.
Ready to test fit a box before joining these three sections to make up my 6' bench.
It has been almost nine months since I have been behind a welding helmet and my welding *****. I definitely need to get back into a rhythm again.
On a positive note, my GC had his HVAC guy stop by today while I was working in the shop. He measured for the heater flu and gas line connection. He said he would be back in the next couple of days to finish it up.
Mike
jbmatth
Northern Ok.
Great to see some construction in the shop and not on it. I'm sure even your terrible welding is better than my best.
JB
Z
zmotorsports
Northern Utah
JB
Thanks JB. Yes it is great to be working in the shop vs. working on the shop, even though technically the work benches are for the shop.
I definitely needed to get behind a helmet again and work on my welds.:wtf:
Thanks for stopping by and checking on things.
Mike
Z
zmotorsports
Northern Utah
Smaller bench (6') welded and ready for paint.
Mocked up with toolbox to ensure measurements were accurate.
Mocked up without toolbox but in location.
Thanks for looking.
Mike
richzuki
Ontario, Canada
Everything about this shop is amazing. The empty shop was already a dream and now to see all the equipment that goes in it...breath taking!
Amazing work Mike
Z
zmotorsports
Northern Utah
Amazing work Mike
Thank you. I am flattered by your comments. I appreciate you taking the time to follow along.
Mike
Z
zmotorsports
Northern Utah
Framework after painting.
Feet installed in the frame, leveled and installing the toolbox.
Toolbox installed and in position. The area to the left of the toolbox will be a storage compartment. I will fabricate a door for it at a later time.
Getting back in the rhythm of things with the squirt gun. I can definitely tell it's been a while though.
I was able to get four of the seven sections completed for the corner bench which I hope to make some progress on tomorrow then I can measure and order my tops.
Thanks for looking.
Mike
Z
zmotorsports
Northern Utah
Oh this is going to be good :eek: Hurry up :evil:
Kickass Mike, let all the fun stuff begin.
Thanks guys. I appreciate the encouragement.
It's starting to feel like home now with all of my equipment in the shop and actually working in the shop. It will still be a while before I am able to get everything organized and stored in cabinets though but before long I should be able to walk right to things like in my old shop. This disorganization and chaos is not good for my OCD though.:scared:
Mike
Z
zmotorsports
Northern Utah
Mike, how did you connect the tool box to the engine lift? Magnet?
Dan, after removing the top drawer there are several hole that are accessible and I put a bolt through and connected to a strap across the top then lowered it in place.
But I like the magnet idea better.
Mike
Z
zmotorsports
Northern Utah
It's good to see you're finally using and enjoying the shop.
Thanks. Yes it is. Working in the shop today it started raining a little bit. It was kind of nice to be working with the shop doors opened and enjoying a little thunderstorm rolling through.
Thanks for following along.
Mike
Thumper68
Duluth MN
Thanks. Yes it is. Working in the shop today and it started raining a little bit. It was kind of nice to be working with the shop doors opened and enjoying a little thunderstorm rolling through.
Mike
Bay far one of my most favorite things is to be working in the shop and watching the storms roll through.
Until I am welding, hood down and that huge crack of thunder makes me jump ruining a great weld bead.
Shop is looking awesome Mike, How many of the benches are you building?
Z
zmotorsports
Northern Utah
Thanks.
I am building one 6' bench and then a corner style bench that will be 10' and 12'.
Thanks for stopping in.
Mike
Z
zmotorsports
Northern Utah
Grabbed a couple pieces of receiver tube out of my metal supply and drilled a hole in each one and tapped to 3/8"-16 thread.
Then welded a nut on each one.
The 10' section mocked into position.
Then went to work welding up the 12' section.
I added one receiver tube to each end so I can fabricate adapters as needed.
Corner bench mocked up and ready to paint tomorrow morning.
Lastly I cleaned up the shop from its first messy job.
I guess I must be getting older because it's late Friday night and I am still in the shop working. The wife had to work late so my son and I are in the shop working and BSing. I don't think life gets much better.
Thanks for looking.
Mike
Z
zmotorsports
Northern Utah
Shop is DONE!!!
Well it is Friday night @ 10:45pm on July 28th and after almost six months to the day the shop is finally DONE!
My GC sent his plumbing contractor to connect the gas line at the meter as well as the heater and hook up the flu and get the heater up and running. He called me about 4:30 this afternoon and asked if it was too late to come by and work on the heater. I said HELL NO, come on by. He just left about 10:30pm after getting here around 6:30pm. I was shocked to see him stay to get it done but I was happy to see him get it done all the same.
Tomorrow I will be painting the last two benches and getting them set up then next week moving on to organizing and then chopping away at my projects list.
Thanks to all for following along on this adventure.
Mike
Boosted1
Georgetown, KY
Is your receiver tube stock seamless? I had that idea, but the tube I had tried to use had a seam which made it a no go.
Shop is looking great.
Z
zmotorsports
Northern Utah
Definitely winding things down on the shop.
Twelve foot bench in place.
Ten foot bench in place and bolted to the 12' bench.
Once the benches were in place I moved on to some much needed vehicle maintenance. Starting with the wife's car. This was the first vehicle on the lift in the new shop.
And lastly I threw some chops on the grille and some peppers for dinner after closing up the shop for the day.
Thanks for looking.
Mike
shortykorte
Tallahassee, Fl
That corner bench is looking the bomb and very functional.
I'm thinking you might need better lighting. lol. Another fantastic shop for me to inspire towards.
Z
zmotorsports
Northern Utah
Thanks Shorty. I appreciate the comments.
Funny you mention the lighting. I have had two people now want the light information after being in my shop as they want to upgrade from their T8 lighting. I'm so glad I opted to upgrade to these LED's when I did.
Thanks again for following along.
Mike.
