This is a cheater bar
GeorgiaHybrid
Extreme NW Georgia
That's a bit longer than mine, I just use the handle from my floor jack unless I need to get something really long...
A couple of weeks ago that was a 8 ft pipe on a 3/4 braker bar to get the bung out of the end of the air tank.
Mugen AP1
Toronto
I've done worse. 60'' Pipe wrench with a 10' bar....plus the weight of the forks on my forklift...:Freak:
Jononon
That looks...adequate :eek:
We something about that size for the nut thats holds the prop onto a P51. The manual calls for "a 150lb man hanging off a 6ft bar"
A 150lb man? That can't be a manual written for the North American market ;)
walrus
Maine
I used an excavator on a 4ft pipe wrench trying to get a 6in plug out of a gas tank. Plug never moved but the wrench blew up in fine fashion:bounce:
Dust
Santa Ana, CA
I had to do similar when removing the heads on my 360. Only had a 3/8" breaker bar in the tool set, but there was a five foot pipe laying by the wall...
Stick
Alaska
Tight is when you lift one corner of your service truck off the ground using the crane on the truck to pull on the 1" ratchet loosening nuts on heavy equipment. Boss never did ask how the two piece handle got bent, but I did get a raised eyebrow when I told him I needed a replacement because it was bent...
some zilch
eh, thats nothing. i used to have change the deck of my 70 ton lowboy trailer back and forth between your typical flat lowboy deck and what's called a beam deck. the two big bolts that hold the decks in place seemed to get tighter as it went down the road. Nothing a one inch drive breaker bar being pushed on by a 40 ton excavator couldnt fix.......
Art From De Leon
De Leon, Texas
Breaking tool joints where someone forgot to get them broke when the tool came thru the rotary can be interesting, when you can't send them back to the shop to have them put in the "breakout" machine.
About the only thing that can be done is ask if they can pick it up and set it back in the rotary table, and put the rig tongs on it, when they are tripping pipe.
Otherwise, you can cobble together some interesting interpretations of engineering, usually using one of the rig cranes.
fatfillup
Finksburg, Md
Have a customer with a 48" pipe wrench with a bent handle. Said he was loosening a gland nut on a hydraulic cylinder. Put the pipe wrench on the gland and lowered the blade of a Cat D8 dozer on the handle. Couldn't believe it didn't snap.
bgott
Houston, TX.
Y'all wouldn't believe how many 36" and 48" pipe wrenches with bent handles I see at the flea market. I don't think anybody uses them without a cheater.
