RotaryLove
I'm currently in a bit of a bind with my air compressor at home. Recently while trying some media blasting I had finally given up due to moisture issues with my compressor. It gets quite humid here in Minnesota which definitely exacerbates the problem. I've come to the conclusion it's time to address this before I begin paint and bodywork on my RX7. I have a 16CFM 80 gallon Compressor, which has quick disconnects to a short 3/8 whip to my regulator. To avoid this bottleneck it would be necessary to plumb with 3/4 (if I'm understanding the attached resources correctly), though seeing as it's just a home workshop I believe 1/2 should be sufficient for even painting while keeping costs down. My original intention was to use a 1/2 oil cooler off of the output, to a short copper section with a drip leg, then off to my filter setup.
I've been trying here and there for a week and a half trying to find a solution to this problem, though the hardware is holding me back. I ordered in a Hayden 1240 just to find the cooler not to my likings - too large, poor mounting system. Junkyard stuff is out of the question since it will be saturated with oil and have fittings that will cause restriction and to my understandings, pressure drop. I've been contemplating building a small box to house a 1/2 copper coil.
As for filters and regulators I'm lost. I have no idea which brands are quality or which are garbage. At the moment I've been considering two options- Pneumatic Plus 1/2 filter/separator/regulator set on amazon, and a setup consisting of separate parts: cheap home center 1/2 regulator, motorguard air filter, SMC water separator, and devilbiss dessicant drier worst case scenario.
It's time I get this wrapped up so I can continue on my projects as I'd much rather do. What has everyone else here done to alleviate this problem?
http://docs.engineeringtoolbox.com/documents/1280/compressed-air-pipeline-capacity.png
attached chart by engineering toolbox.
http://www.industrialaircompressors.../how_to_determine_Pipe-Size_chart_2-18-11.pdf
