Bending pipe
Throbbin Rods
Lebanon, NH
Starting a project to build a steering connector for my duck boat so I can run a kicker motor in the spring for salmon fishing and steer using the main motor. I picked up the connection piece for an EZ Steer set up in a yard sale for short money, so I just need to build the pieces that connect to the two motors. They will look something like the attached picture. I will be using 1/4" steel threaded pipe for the 90 degree pieces. Wondering how small a radius I could bend by filling the pipe with sand first and thought someone here might have experience. the larger 90 degree piece will be about 7" overall length and the smaller will be about 3.5" overall length. I have no issue with using longer pieces and cutting to length after bending but can I get a tight bend using sand?
Thanks much!
Bill
T
Throbbin Rods
Lebanon, NH
This is a better representation of what I want to build. One to fit the main motor and one to fit the auxiliary motor
matt_i
SE Michigan
My opinion, and its just that...is if you use a mandrel that has a half-round groove in it and a 1/2 round "forming tool" the NPT black pipe is going to be thick enough in the wall not to need sand.
If you use a flat-sided (albeit round but with no groove to support the cross-section as its bent) mandrel or "forming tool" then it will kink much easier.
The tool in my shop I would use for bending is the Diacro rotary bender.
Heating a tube has given bad results to me, it makes the cross-section weak and wanting to kink. Supporting it with the groove seems to go a lot better.
MoonRise
Does it need to be pipe? Or can you use solid round bar?
Solid bar, just bend it.
Hollow, and no kinks or wrinkles? That's the tougher one.
tthornto
Solid aluminum (depending on what alloy) doesn't bend very well without cracking, could you use stainless steel brake/fuel line tubing? Then you can get fairly tight radius bends using a common/cheap tubing bender, and rust won't be an issue either.
T
Throbbin Rods
Lebanon, NH
Thanks for all the suggestions. I may end up just using solid steel bar and tapping 1/4" pipe thread on one end. Brake tubing wouldn't take the constant vibration I don't think.
thanks again
Dutch01
Kempton Park, South Africa
Without a pipe bender you can cut slots half way through the pipe and then bend it. A smaller radius will require slots close to one another. Here I have bent 16 mm pipe with a 1.6 mm wall thickness. Slots were cut with a 0.8 mm cutting disc.
If you do not get the required angle after bending, cut again into the same slots and bend close again. Weld up slots and finish off with a grinder.
