Poured a weight block last week, Thursday August 17 in the AM, to be exact.
I kept the form and concrete both wet and covered with plastic until yesterday afternoon, when I moved it into my shop so I could get it out of the way.
Took off one end of the form this morning (i.e. exactly one week after the pour) and the concrete was not only still green looking (instead of grey) but also still pliable! Parts of it hadn't hardened at all! I stopped taking off the form at this point.
Pics:
In the 2nd pic, you can clearly see my thumb indentation in the center. I'm pretty sure concrete is supposed to be stronger than that.
Recipe is as follows:
80 lb bags of standard Quikrete concrete mix, about 3-4 quarts of water per bag and 8 oz of BASF 1025 superplastizier. Quikrete recommends 3.5 quarts of water with a maximum of 4.5 quarts. I don't believe I exceeded this amount and probably it was a bit less. One of the purposes of this pour (besides getting a weight box and using the concrete before it went bad) was to test the SP).
I mixed the dry ingredients for about one minute, add water for about 2 minutes, let that mix for 1-2 minutes, then take a minute to add the SP. After all ingredients are added, I mixed it for an additional 3-5 minutes. ETA: Mixing was all done via a HF electric 3 cu ft mixer.
The top itself seems hard and has turned grey, although it's not shown in the pics.
What happened here and is this salvageable?
Now can you see the pics?
Pics:
