ahazi - Welcome to the forum. Please add your location to your profile.
Los Angeles, CA
I'm not sure I understand the purpose of the comparison.
I am in the finishing stages of building a shop (difficult site and tons of Los Angeles city codes that I had to comply with.) I wanted to get ACTUAL (measured) light performance and electrical results from testing 3 light fixtures that I had on hand to convince myself of what will work and what will not work in my application. It is not only about the lowest cost and highest efficiency per watt but also about aesthetics, physical size and added functionality such as dimming that is very useful to me.
Each fixture listed is for a different application and/or mounting height. You have an outdoor flood light, a 13,700 lumen highbay LED, and a 4 lamp retrofit that would surely put out more than the 4800 lumens charted. The 4 lamp retrofit would put out 10,560 lm with the LumenGen lamp and cost $80, or 5,280 lm and cost $29 if you use a 2-lamp strip housing.
You are right, thank you! I made a typo in my table (sorry...), the nominal output is 8,800 lumens. Here is a link to an updated file:
https://drive.google.com/open?id=0B1yETuTzaCJsR3k3NEVPTjFsaWM
Is the room pictured where you are installing fixtures? It appears to have an 8ft ceiling.
The room is about 1,000 sq ft with 11 ft high ceiling, the testing was done by hanging the tested fixtures on a hoist I-beam rail that is attached to the ceiling and mounting the
Android phone with Light Meter that was doing the light measurements on a 5 gallon bucket (8 ft distance). The actual distance for the installed lights to the benches will also be about 8 ft.
If my assumptions are correct, none of the fixtures tested are appropriate. Suggest using 2-lamp 5,280 lm retrofit strip lights on page 1 for $29.
Not true for me. I like the dimming feature and the super high output of the high bay unit. This will give me more flexibility as I will have extra light when needed and can dim the light when appropriate and reduce power consumption. Also the high bay units are sealed for dust and dirt and have a light diffuser. There is a newer model of this high bay light
http://www.ledlightingwholesaleinc.com/James-High-Bay-2-Foot-110-Watt-p/zy-h2-110w.htm with claimed output of 16,400 lumens at 110 watt. I ordered these units and will report results or this might turn to be just marketing hype.
Also my room is not exactly square and fitting in the 2 ft unit is much easier and my measurements indicate excellent light distribution characteristics.
Usage of flood light in a shop is debatable but it can work in certain places. It is cheap, small and sealed. My measurements and observations and past usage don't make me dismiss it completely for some applications but not here.
Lastly, I did this test because I don't trust the published specs for my intended usage and I wanted to measure vs. just believe the spec sheets and the computer simulation. I am an old dog in the technology business and learned over the years that the only thing you can truly trust is what YOU (or someone you trust) measure. You can see this anomaly in the row "Lux/watt (measured, not calibrated)" which shows the discrepancy from the manufacturer specified performance numbers.
Again, any thoughts or comments will be greatly appreciated.
Ariel
https://goo.gl/photos/z79iUmDpCkF9FzDH7
