The VISES of Garage Journal
KMScott
Jeff is that a nice one, will not last long. I am working on a 544B Rock Island combination vise (Missing Pipe Jaw as usual) with the same 577 6" jaws and wanted to remove the swivel base until I seen how bad they designed the shoulder bolt and shoulder bolt swivel hole. How can anyone get a 1-3/8 open on this one. It is rusted in place which made matters worse. 5 minutes on the weld table and it is out. Just have to clean up the welds, add a nut some how and remachine the pocket so a socket can be used. Welding the nut heated the nut and broke the rust seal, some times you can get in trouble and Gaul the threads but I got lucky.
I have to re engineer the pipe jaws on this big vise and if anyone or even open for suggestions on how small of a pipe should be used as a guide line for the teeth design then I am all ears. The three pipe jaws are 3/4 wide, 4 inches tall and the pocket depths are 1-5/8 deep and 1" behind the jaws. Thanks in advance.
Bcom
Nebraska
Hey Kevin, I got a Yost 80C sitting here if you need any pipe jaw dimensions from it.
KMScott
I am looking for the smallest pipe a 6" vise grabs. Is yours a big one? Not up on Yost vises unless it is a old one. Pictures are great, you can tell a lot from pic's. I hate searching for pic's on the web. The Yost #6 pic I added might have had pipe jaws and maybe it is like yours.
Bcom
Nebraska
Yes it's a big 8" with the pipe jaws. I can get a better pic if you want. This is what I have on hand at the moment.
Bcom
Nebraska
Here's another pic if it helps. Thats a 4" wilton in front.
ricleh
Sacramento, CA
My Wilton C3 has a pipe jaw capacity of 1/4" to 6".
KMScott
Bcoms vise has the Starrett type pipe jaws and looks like the Pipe jaws sit back from the jaw face. I think I will go with that design. ricleh, the Wilton C3 Pipe jaws are close to the same but are a little shorter by 11/16. Thanks guys, looks like I can scale down the 326 (5 inch tall) Starrett Pipe jaws..
va.grouseman
Southern-Central VA.
Previously posted by Chasbec.
I'm not in the market for this at the moment but thought this was very interesting. Thought I'd share it here.
https://hudsonvalley.craigslist.org/tls/d/old-anvil-vise/6270392950.html
Chasbec, that is right odd.---The Anvil is the dynamic on that one.---Looks like it has a slide in pipe jaw missing.
Evergreentree
Montgomery County PA
Hey guys, it's been along time since I've Visited the gj. Wanted to share my chainsaw sharpening set up. Parker 975, Dazor light, Philadelphia tram rail pulleys, on top of white oak, pub table base with extras
Evergreentree
Thanks va. Was out for a while, bought our first house which came with half a dozen pole vises, and another half a dozen beat to snot machinists. To bad, mostly prentiss. Also scored this sweet condition no 6 of late. Good quality vise. Is there an age estimate on the peramo's. Ww2 timeframe only or thereafter? I'm sure this has been discussed many times.
volunteers
California
thank you guys for the help. I finally moved the new wilton 600s on my bench by myself. I found the body of the vise has coarse finish. Is it normal?
when I turn to close the dynamic jaw, the last one inch is kind of stiff. any reason for that?bad70f0c1f73a064ad4f06a0203e43cd.jpgec83c48d957980e34d4a5ef2ff61ce49.jpg
Sent from my LON-L29 using Tapatalk
https://hudsonvalley.craigslist.org/...270392950.html
CL Add is missing...
damnesia
Northern MN
I'm trying to disassemble the Reed 31 I bought a few weeks ago, I'm actually going to strip it and paint it ( the first vise I've done this with, most I clean up enough to work and just use them ). However I can't stand the blue paint on it so i'm going to bite the bullet. I have the screw out of the nut but I can't get the dynamic jaw off. I don't see what's holding it on, unless it's just so filthy I can't see it. I figured before I screw something up I'd ask here. Any advice on how to remove the dynamic jaw?
I'm looking forward to repainting it. I've recently stripped, rebuild and painted a Seattle Chain Co. screw geared chain block and it looks awesome ( until the first time I really use it ;) ) and I'm excited to get the vise looking good to.
One more thing, I assume the original color of a Reed 31 is probably black?
Thanks.
jonhdw
Cleveland, OH
Thanks.
Check the slide to make sure it's not mushroomed over from being used as an anvil. Almost every time I've had a dynamic jaw stuck it was because of that.
damnesia
Northern MN
Turns out it just had a bunch of filth at the end of the dynamic jaw "slide". It's apart now. One more questions, and not a super important one. How do I remove the handle from the lead screw? The handle is bent to all hell and I'm going to have to remove it at some point but I'd like to try it before the electrolysis bath. The round knobs on the end have a little play, but don't seem to be threaded on.
va.grouseman
Previously posted by Volunteers.
My 800 is like that , all except where they had to grind some seam ridges down.---I think that's from the sand molds.---I kind of like that rough texture look.---There is a rough casting look that has nothing to do with sand, it's just bubbles and bad casting.---I have a 208 Yost that looks like the surface of the moon.
G-ManBart
It's common to see some pretty obvious grinder/belt sander marks on the body of vises. They aren't trying to make them smooth and polished because it's not necessary for function.
The slide will sometimes get gummy with the factory preservative, so clean that off, put a light coat of oil/grease on it, and put fresh grease on the screw. There's a good chance it'll feel fine after that.
G-ManBart
They are peened on. You have to cut/grind some off the end to get the ball ends off. You may want to look at the Vise Repair 101 thread where all of this is covered.
damnesia
Northern MN
Thanks. I was searching through this thread but I'll check out the Vise Repair 101 thread.
sandman54
Ft Worth Texas
My latest acquisition a baby Reed! It will also be here thursday.. have a nice day Sandman:rocker:
va.grouseman
That's one of those watch maker's/salesman sample, ain't it Sandman.---That will work good for fly tying and setch.:D
Man that thing looks clean and crisp for a big chipper.---Jaws good and square.---Nice score.:thumbup:
twertsy
Reedville, VA
That was a tough one to find! Listed under "Combination Tool" Here's the patent
Bcom
Nebraska
Hey Kevin, if you need to see the jaws in person, i can take them out of the vise and send them to you if you need. I also have multiple Columbian 204 1/2 pipe jaws here too if you'd like to see them as well. :thumbup:
Fixed it Outlaw.
Thanks VA!
Pic for posterity:
jonhdw
Cleveland, OH
Are you planning on keeping the handle and straightening it? It might be easier to just cut the old handle off and make a new one.
KMScott
Another big guy for your collection. Nice find sandman
Thanks but no thanks. I have a master drawing that I will use, I just scale it till it fits. Send the columbian stuff to damnesia. There is a possibility he might take the bull by the horns and make Columbian jaws.
Bcom
Nebraska
LOL! Aww come on. The Columbian stuff ain't so bad. :lol:
dutchgray
Dorset. England.
Im pretty sure Paramo was still making vices in the 80's, although they did modernise the design at some point, they started because of WW2 but I don't think we would have exported any for sale during the waw.
AngryBeaver
Lake Milton Ohio
Clean it out/take off the old grease first. Make sure there isn't an rust or corrosion. If that doesn't do it.....
Take the Tail cap off and see if the screw is contacting the inside tube of the nut the last inch or so when the jaw is closed.
I had a brand new 450 do this. I ended up flipping the nut and redrilling the holes for the pins. It wouldn't close that last 1/2" without extreme force. The nut was drilled just enough off center that it only became an issue when fully closed.
va.grouseman
Previously posted by Twertst.
That was a tough one to find! Listed under "Combination Tool" Here's the patent.----https://www.google.com/patents/US574764
That is some fine digging Twertsy.---You got a real talent there for digging, and a good asset to this thread.
So Would you call that anvil vise a Salzman sample?:bounce:
I sure like to have it, but I would have to do like the government and raise my debt limit.:sad:
meatsis
Hudson Valley NY
VA Good luck dealing with that guy. He finally updated his ad. It used to say "don't ask me how big it is or how much it weighs".
He also claims that it was appraised at $2500.
He bought it off Craigslist from somebody who had it listed for $200. Once he bought it, he put it right back on CL for $800. With the SAME picture from the original sellers ad!
Now he claims it's been in his family for several generations. I understand buying stuff and trying to flip it for more money. But this guy is just an A-hole!
va.grouseman
Thanks Meatsis, I don't like dealing with that caliber of people even if they have something I really want and can afford.---We have a couple of fellows local like that, that I don't trade with, period.---They would cheat their mother.
chrisnazzy
Arizona
Oh yeah......which one of you fellas grabbed this nice looking Reed 105 off Ebay today?
Bcom
Nebraska
Just picked up this old rebuilt Reed 3C today. It was rebuilt 50 years ago with new Reed parts and left on a shelf afterwards with no use. The new Reed parts consists of a whole new spindle, new pipe jaws,new pipe jaw pins, new nut, new 2 piece nut, and it appears the base bolt is new as well. This vise is in excellent shape. It came out of a Proctor&Gamble factory. I got this from the original Proctor&Gamble maintenence man that rebuilt it in the factory. Says after he rebuilt it, it got put on a shelf with a bunch of other vises and it sat for 50 years unused. P&G decided they were throwing out all the old stuff with the vises and the guy was able to save the only one he rebuilt. He even gave me an old yellowed Reed parts paper they used to order parts from. This is the nicest Reed C series I've come across yet.
