I have a 25amp air conditioner I need to run wire for. The heating and cooling guy said the max amps are 25amps. Sow I need 10ga wire right with a 30amp breaker? Do I need 3wire cable + ground for outdoors or is 2 wire ok for this install? What kind of disconnect do I need and Is there one I could use to easily plug in a emergency generator with?
https://www.lowes.com/pd/Square-D-60-Amp-Non-Fusible-Metallic-Enclosed-Circuit-Breaker/3364886
http://www.homedepot.com/p/Square-D...e-Over-Current-Protection-QO200TRCP/202353314
