The goal is do it once and do it right 40x64 pole building.
NebrTd
Nebraska
I have been searching via google for some time on this forum and recently joined. My project is a 40 x 64 x 16 pole building. The project started with the frame last July and as of yesterday it received concrete.
Things to do,
Finish insulation, which is 4'x4'x5" foam blocks. That I hope is worth the effort.
I have been watching the high bay LED thread preparing for lighting.
Trying to decide on a floor coating, leaning toward polyurea if I can swing it.
It will have a steel liner for the walls and ceiling.
Heat will be radiant tube heat fueled with propane.
20 x 40 loft.
Plenty of other details to come. Hopefully I can keep on it to keep this thread progressing.
N
NebrTd
Nebraska
A few more pics.
N
NebrTd
Nebraska
I haven't moved as fast as I had hoped. I have more done but not much that is photo worthy other than the floor that I just completed this past week.
I used Legacy Industrial densifier and stainguard.
Toomanytools?
Washington
NebrTd:
Nice build going on, I'm trying to decide on my floors and came across yours. Looks like you burnished the HD40, I think that is the route I'm going it gives the protection from spills but let's you weld and work on it plus gives a bit of shine. Also it is one of the lower cost alternatives.
Looking at your ceiling looks like scissor trusses then you framed up joists on 4 foot centers? What is your plan for that? Going to cover with metal?
N
NebrTd
Nebraska
Yes planning to do a complete steel liner on the interior. The framing in between the trusses is because I plan to run the steel panels parallel with the trusses.
N
NebrTd
Nebraska
Made a little more progress with the help of my brothers this weekend.
LXCam
Wow that's looking great. How big is the mezz and what ya planning for underneath of it?
N
NebrTd
Nebraska
Mez is 20 x 35.
All of my tools will go under the mez. I plan on it being my fabrication area. Under the mez is also a bathroom and a "kitchen" for my meat processing equipment on the left side in the picture.
N
NebrTd
Nebraska
I am finally starting to finish the inside of the building. So much for moving quickly over the last year.
Here are some pictures of how I am doing my lights under the mez. It is an 8' ceiling and I did not want the lights to stick down any lower than they had to. They go in and out just like a suspended ceiling light but this will all be covered in a white steel liner.
mbrew
Ft. Worth
Good looking shop with some real nice space. I will be doing something similar for light fixtures in my shop and was planning to fabricate the pieces. Mind if I ask where you found the parts for your housings?
N
NebrTd
Nebraska
The housings that hold the led lights? They are made from z-trim or wainscot trim. I just cut them and bent it into a square and riveted the corners. Then I put J-channel around the perimeter.
N
NebrTd
Nebraska
A portion of the interior liner is installed. A lot more to go.
N
NebrTd
Nebraska
This thread could probably be named " the slowest shop build ", but none less I am making more progress. It feels like I can see the light at the end of the tunnel at least.
N
NebrTd
Nebraska
A few pictures of the interior of the shop 90% done. I need to trim around the windows yet.
The red and white "T" shaped tools are what I made to put up the ceiling. They were a lifesaver.
Nick in WI
I really like your building the size is just right. Good call on the T shaped tools. I'll definitely steel that idea when it comes to doing steel ceilings.
