ocloc24
Yep, that and a variable speed (dial to set max and trigger to feather) die grinder.
It pains me to say that I'm pretty jealous of DeWalt's grinder offerings for the 20/60v things. Milwaukee's gotta step it up!
My only issue with the Milwaukee, it's pretty irritating that it's all or none. Especially with how quick it eats through the battery, if you could feather it down when you didn't need 20K rpm would be great. Hey, Milwaukee still did it first.
kctyphoon
Jersey/Staten Island
I'd suggest the 1/2" Fuel mid torque model 2861-20.
Lots of people like the compact impacts, but I found them to be underpowered for many things...probably just me but I had a hard time finding what they were good at. The mid torque is just a little bigger but much more powerful. Just my opinion.
I'd agree with this. If you're getting by with the older brushed model, the fuel mid torque will save you size and still be a step up in power I believe. The mid torque is not a replacement for the bigger fuel models though. The best option for most mechanics of course is to get all 3 model sizes.
The only thing Milwaukee is missing now is a killer 3/8 model.. I'd expect one from them soon.. (hopefully)
ocloc24
The thing is I already have the 2663-20 but the one you list seems to have maybe a bit more power and smaller.
If you have the 2663, you won't be happy with anything less than the 2763 or 2767, the 2767 is the newest one. 1400 ft/lbs and not much bigger than whatt you have now. The mid torque is only a 150 ft lbs over what you have now.
kctyphoon
I don't have the model you do, but it will be similar in size (maybe even bigger) then the gen1 high torque model shown here. The mid torque (middle, without the boot) will be a little more powerful and a lot smaller than what you what you currently own. The smallest one here is the gen1 3/8" fuel. You can see the mid torque is not much bigger but is a lot stronger. The newly released 1/2" gen2 high torque fuel model will be about the size of what you own, maybe a little heavier, but is about 3 times more powerful than what you're using if you can imagine that.
ocloc24
Speaking of die grinders, does anyone know of collets that will work in the M18 Die Grinder? Standard air die collets don't fit, and the ones from Milwaukee range from $40-50..
Mohawk Dave
SoCal
That's disappointing. They did same BS with the little M12 polisher that takes rolocs. The threads for the backing pad are some one off metric so none of my normal stuff is interchangeable.
Stuart96
Central ca
I use the power extra 2.5ah batteries daily and they work as good as the Milwaukee battery, one of them I use daily in my stick light and it sees daily recharges.
ScottsGT
Lake Wateree, SC
Their pack out organizer is a bit pricy at $44. I stocked up last year on the Dewalts for $24 each. They're a little late to the game, and I'm not changing just because of red vs. yellow.
isuhunter
I just got the Rover. Some kits out there still have the free XC battery inside the box. They share the same sku and same price but if you are lucky enough you will find the one with free battery inside. The part # ends in P and has the picture of free battery on the box.
Found one of these at the local Home Depot today also
mobiledynamics
Gotham City
Those Rovers are awesome. I have 2 of them in my stash but you know.....the floody get' the most use out of all my M18 lights. Size/output -- for inside room work, is more than sufficient . The rovers in use - are like 2X in volume
ocloc24
Broke down and ordered the mid torque today. Too much stuff I work on is well over 200ft/lbs but under 500.
dacan23
RI
Its a good light, surprised the free battery is a 3.0, back when I got mine it was a free 5.0. While I like the dual power capabilities, I never use it but have a large cache of batteries.
Now I have 3 dual power lights; 2360 Rover, 2146 Pumpkin, 2135 Rocket2. Just got 2 pf them, hoping tonight to test and compare the many lights I have, especiallt Rocket1vsRocket2 before my friend takes my Rocket1.
Still disappointeed Milwaukee doesnt include a nice 12-15a cord with the dual power lights.
DFB
Southern VT/Western Mass
Ya I kick myself I didn't bite when its was a 5.0 XC offer with that Rover light.
I really should have at least one with AC capacity and the lumens rating with that flood light is pretty good.
Bighead38
Rockland County NY
Where did these come from? I didn't see them announced anywhere.
https://toolcraze.net/milwaukee-shockwave-impact-extractor-set/
Milwaukee® Introduces the SHOCKWAVE™ Impact Extractor Set
09/01/2017
MILWAUKEE, WI – Milwaukee Tool demonstrates its continued commitment to delivering productivity-enhancing accessory solutions with the introduction of the new SHOCKWAVE™ Impact Extractor Set (48-32-8000).
For a superior grip to remove damaged, stuck, or corroded fasteners the Milwaukee® SHOCKWAVE™ Impact Duty™ Extractors are engineered with an optimized geometry made from thick, hardened alloy steel that is reverse-threaded and tapered.
Unique to the SHOCKWAVE™ Impact Extractor Set are laser-etched and color-coded bands so users can more easily organize and identify the size they need for the job at hand. For added utility, the new Extractor Set comes in a flexible plastic holder which prevents against any pieces getting lost in storage bags, totes, or carts.
Included with the set are (5) Impact Duty™ extractors for fastener heads 1/4″ to 1/2” that accept 3/8” square drive tools as well as a 1/4″ to 3/8” SHOCKWAVE™ square socket adapter with up to 30X life for use in quick change impact drivers.
With its user-driven focus, Milwaukee Tool demonstrates its continued commitment to delivering innovative accessory solutions to save time and increase productivity on the jobsite. Visit www.milwaukeetool.com for full listing of new SHOCKWAVE™ accessories.
ocloc24
Has anyone found suitable replacement collets or collet nuts for the M12 Rotary Tool? I have the Dremel keyless chuck but for certain things like the flex shaft it's better to have the normal collet/nut
kctyphoon
09/01/2017
Dewalt has a set.. I believe they are currently marked down in Home Depot stores.
Here, I think it's $17.99 in the store now
http://www.homedepot.com/p/DEWALT-Max-Impact-Extractor-Set-5-Piece-DWABEXTRACT5/300703144
Has anyone else had an issue with the smaller sized Milwaukee hammer drill bits.. At work we have a fairly new 3/8" in regular and sds form, both tips broke off them.. I just stopped and bought 3 more of the sds, and like 8 of the Bosch standard chuck 3/8" bits. Guy at work got mad that I took his bit out and threw cause it just danced around instead of actually making a hole.
jfranci3
Anything that fits the small dremels fits the Milwaukee. Only exception I found was a Sears planner attachment, that also doesn't fit dremels. I had to modify the tool a bit to get it to fit.
KWtech90
Hey everyone. Irma just came through here and I grabbed my m12 hackzall to cut up a few downed limbs. It performed pretty well, but I noticed the clambshell started to seperate at the front of the handle where the battery is inserted. There doesn't appear to be anything physically broken per se but with hand grip pressure the plastic seperates enough for the battery to loosen up and pinch skin when in use. Looks like an engineering fail as there is no fastener there to keep everything held together at the front. Any chance milwaukee could remedy this with a warranty claim or is it just something I'll have to live with?
kctyphoon
Give em a call..
Shaners256
Milwaukee
Is the little silver piece still in the rear of the handle? It's supposed to hold the handle halves together. It's #20 in the below link.
https://documents.milwaukeetool.com/54-40-2510.pdf
boomer12831
northern New York
I would like to get the M18 Fuel 6 1/2 inch circular from Acme. It's the 2730-20 bare tool for $179.00. Has anyone used this saw and what do you think? It seems to be the cheapest I have seen.
isuhunter
Saw it and remembered seeing a post here so I grabbed it. Is it worth the 150$? Thought having a cord would be a nice option also.
ocloc24
I'm seeing $157 as the lowest on eBay and multiple others for $159. I haven't used it but heard good things.
kctyphoon
Just FYI, it's the same exact motor that's on the 7.25" saw, spinning a smaller blade. I have both saws, haven't used either much but both are pretty impressive. The 6.5" is a left handed blade, honestly I find it a little awkward to use after using the opposite sided saws for years.. you might have a different experience using it though..
Distrophe
CpoMilwaukee is $175 currently. Not sure about shipping.
Ocloc24 posted cheaper eBay prices but sometimes $15-20 is worth it for a better warranty possibly. Or at least a better return policy.
cgrutt
What would be best M18 tool to cut up demo work into smaller pieces to fit on trailer? Current project has a bunch of 1x2 fir strips that are as long as 16' and a bunch of particle board mostly 3/4" covered both sides in formica as big as 4x6 sheets. There is some electric work attached (nothing live), mostly BX cable. Would a circular saw be a good option here? I have a saws all (not fuel). Is there anything else that would be good for quick work to cut scrap into manageable pieces? A chain saw would be great, LOL...
cgrutt
Sawzall with the appropriate blade will be the fastest imo.
Thanks. I have an M18 sawzall but not a Fuel, was kinda looking for encouragement to buy a new tool, LOL.
You're probably right though. Thanks again.
chrisnazzy
Arizona
I love my M18 hackzall! Use it for everything from quickly cutting wood down to cutting fenders and bumpers and other metal. The other day I threw it in a bag with my 12" Diablo pruning blade and went over to my sister and brother in laws house and trimmed all their palm trees. You really can't beat the balance and feel with only one hand operation. I'm am 100% planning on picking up the new M18 Fuel version once it's released!
cgrutt
Have to look that up, thanks. Not sure what you're talking about, LOL...
cgrutt
Do they make a rotary tool with 3-4" blade? I remember using them back in the '80s and they were great. I think Makita was the only brand available at time. I'm getting f'n old, lol...
dacan23
RI
Even if its just material without nails/metal the blade is just as important as the saw, the Fuel model gives more power and runtime, but a very good blade goes a long way in the normal sawzall. The Ax carbide blades are awesome or the diablo equivalent.
dacan23
RI
Compared Rocket1 vs Rocket2 and 2 is noticably brighter, with the 3 positioning heads its very useful. Glad I shelled out for it. The bag is very nice and V1 does fit in it, dont know what they charge for it by itself. The V1 top is the identical size, length is a tad shorter, but the bottom is smaller.
The Radius pumpkin, was expecting to be blown away..... meh... Its a glorified M18 lantern, yes it produces a lot of light over a big area, but its not super bright to see perfectly. Depends on the work you were doing it may not light the area enough. Of course the first time I lose power I will probably think its great. It would be awesome for camping or illuminating a big area when there is now power.
Rocket2 is $399 vs Rocket1 $199, is it worth double, not sure about that. Considering cheapest V1 cost me after selling freebies was $55 and my final cost of V2 with bag is going to be $260, still a lot more. The corded option will be helpful, charging to me isnt a notable benefit. One Key Pumpkin will end up costing me $200, no way I think thats worth it, $349 is an outrageous regular price.
kctyphoon
I've never seen them, but I believe Milwaukee offers a replacement clear lens for the radius light that makes a big increase in output.. just my opinion, but Milwaukee should have offered a tripod stand for that light as an accessory.. that light on a nice 6' tripod would be a great piece of equipment imo
