signcrafter
- Joined
- May 9, 2012
- Messages
- 12,457
My torque wrenches are 6 hours away. I need to rotate the tires on both vehicles so I was thinking about getting a new torque wrench. My current 1/2" is maybe 15 years old. It's a Craftsman that has served me well but never been calibrated and is just the standard clicker type wrench. So with it being so far away and my need for one and also with a lot of newer cars using angle readings for things like head bolts I thought it might be a good time to look into a "tech angle" type torque wrench.
Is snap on the only ones that make these or are there other manufacturers that make them that are good quality but a little cheaper?
Also is a 1/2" the best size to get for angle readings on vehicles? I mean if you could only have one tech angle torque wrench would you get the 1/2" or the 3/8" one? Where do you mostly use the angle feature? I know I've done heads with angle specs before and I think some suspension parts also. I can't justify both sizes so want to make sure if I get the 1/2" it'll do most everything I would run into. Otherwise maybe I'll just look into a new regular 1/2" torque wrench to replace my old one.
