grind AND acid?
Kaizen
New England
I had to grind down some bad spots on my floor so I just ground the whole thing. some spots I could have done better I think but overall fine. Since I have the acid etch anyway I was going to do that just to be sure its good adhesion. but I've seen a few posts that say not to do both or that its not needed. Is there a downside to me now doing the etch as well?
Shea
California
Acid etching after grinding is not needed. Also, you are now introducing water into the concrete which will require time to dry thoroughly or you will be introducing issues that can develop during application.
K
Kaizen
New England
After grinding and using a blower for hours I still had residue on the floor. I ended up power washing it so I have to wait anyway. I'll take a better look at the floor and see if it has that grit finish now or still smooth.
Armorpoxy
If you grind, no need to etch. But...you should prime first since you grinded.
