jim1450
Trying to gather up the correct stuff for my projects so I'm looking for some suggestions on what to use.
Existing detached garage has 10 NM in PVC that I want to replace with correctly fed 40 amp service from a 100 amp sub to be installed in the basement.
New pole barn being built in Nov/Dec I'd like to run 60 amps to from my main panel.
House has a 200 amp main, have a 100 sub to add about 15' from the main for the garage 40 amps & 60 amp water heater.
I ordered 2 https://www.menards.com/main/electrical/circuit-protection-distribution/main-breaker-load-centers/square-d-trade-homeline-trade-100-amp-20-space-indoor-main-breaker-value-pk/p-1444444027912-c-6437.htm?tid=-3537758112357886712&ipos=3 for the garage & barn, both runs should be under 75'
I have 8 NM to run in my basement for the garage & will use 8 UF from the house to the garage.
No way to use conduit to feed the 100 amp sub or from the main to where the pole barn feed exits through the wall.
So my questions are about feeding without conduit.
1 What's the easiest way to feed 100 amps to the sub?
2 What can I use for the 60 amps to the pole barn from the main to where it exits the house?
So who's all worked up?
