Tire Iron
shawndp
Toronto, ON
So it is late September - that wonderful time of the year when the leaves change colour and one's thoughts turn to the joy of changing tires. I am going to be in the market for a tire change tool - I think tire iron may be the wrong term. Looking for suggestions on what is a good and proper one to get? Thanks!
ocloc24
Impact Wrench. Why break your back?
General Geoff
Allentown, Pennsylvania
For a non-powered tire changer, I've been steered toward this machine:
https://www.nomartirechanger.com/CH200_Motorcycle_Tire_Changer_p/tc-ch200.htm
It's advertised specifically for motorcycle tires, but it will do car and light truck tires up to 21" in diameter as well. Comes with all kinds of bells & whistles that the basic post-style changers don't have, making it far easier and nicer to use. Also doesn't mar or scratch aluminum wheels.
full disclosure, I don't actually own it yet, but I'm probably going to pick one up within a year. If I change four sets of tires a year with it, it'll have paid for itself in about 5 years.
cdeer001
Northern VA, USA
Not to get the tire off the vehicle - to get the tire off the rim.
Something like this?
MT AND DEMOUNT IRON, 37IN, 3/4 IN STK
KEN-TOOL| Zoro #: G1800391| Mfr #: 34645
https://www.zoro.com/ken-tool-mt-and-demount-iron-37in-34-in-stk-34645/i/G1800391/
bobcatdan
Kaukauna,WI
Kent tire tools. If we are talking big tractor tires, longer the better. Also you will need something to break the bead. I get by with a big bead breaking hammer, but I mostly do 16.5 skidsteer tires. Old farm tractor tire may take a lot more. Changing tires by hand is relatively easy if you know what you are doing. Almost impossible if you don't. Maybe better off having onsite tire service come out. If it's just a garden tractor, that should be easy.
theoldwizard1
SE MI
There are basically 2 steps. "Breaking" (down) the bead and then removing the tire from the rim. Both require tools and TECHNIQUE !
There are a lot of different ways to break a bead after removing the valve core and air. If you are careful, you can do it by driving over the tire with another vehicle. Old fashion bumper jacks, 2x4 levers, etc., etc. In any case, you should apply a liquid lube (soapy water) at the edge of the bead and the outer flange of the rim. I have always been impressed with the BeadBuster tool even though I have never used one
It appears to be easy and fast especially if you own a battery/pneumatic impact wrench.
Step 2 is removing the bead. Tools are required from simple tire spoons and a second person, if you don't have a machine, to hold the tire from moving on the ground as well as holding one of the spoons. (If you are going to buy spoons, buy 3. Everyone will tell you, you only need 2, but that thord one will come in handy at times.) TECHNIQUE IS CRITICAL IN THIS STEP EVEN IF YOU HAVE A FANCY TIRE MACHINE ! The side of the tire OPPOSITE of where you are working the spoon/tire tool MUST remain depressed into the "drop center". Manual machines have a long demount/mount lever and a fulcrum (center post) that make this step a one man operation and much easier. Also using a paste lubricant like Murphy's Original Concentrated Tire and Tube Mounting Compound
There are a lot of videos on YouTube. Watch the peoples technique. The one that are not struggling are using lube and keeping the opposite side of the tire down.
The HF tool is okay, but you really need to mount it to a concrete floor. The Northern Tool one is similar but built a bit better. The Cadillac of manual changers is the No Mar Classic. Originally designed for motorcycle tires, it is sturdy enough to do pickup truck tires. Hard to justify compared to the others manual ones, but you won't mess up your aluminum rims.
jessesandy
Upper California
For me, breaking the bead was the hardest part of the process.
But, I was making up home made equipment as I went along.
Straight forward process and a good workout.
The type and condition of the tires will play a big part in how difficult the job will be.
A worn out tire that's only a few years old (fresh rubber) - piece of cake.
A truck tire, or six ply side wall, or a very old tire with stiff/hard rubber - good luck with that.
Also, harder to slide tire irons on alloy rims, and leaves marks.
Then took the loose wheels to a used tire shop that spin balanced for like five bucks each.
lilredex
Toronto
I use a couple of spoons that look like this, that came from garage sales.
http://www.gregsmithequipment.com/Ken-Tool-Curved-Tire-Spoon-30-Long-11-16-Stock-T20A
You can also use spring leaves or similar PAL pry bars.
https://www.princessauto.com/en/detail/24-in-flat-pry-bar/A-p8277329e
I usually use the "Newfie" bead breaker.....place a 2 X 6 against the bead and drive up on it. It broke the bead on my 8" Lil Red wheels that hadn't been touched in more than 15 years.
Then to free the wheel from the back bead, you need to take a spoon and bend the tire back from the wheel and hammer the tire off.
My changes are all car or light truck tires.
