Need tilt-assist device for tilt trailer
rockinacummins
Wapanucka, OK
So I have this tilt trailer that is HEAVY. The bed is 5x13, and is built out of super heavy steel. It is hinged way in front of the axle, so it is almost impossible for me to tilt the deck, much less tilt it and then drive onto it. I'm wondering if there is anything that would work to push up against the deck? As in like a heavy duty gas cylinder?
I actually think this thing was intended to have an electric/hydraulic tilt, but it was never installed at the factory nor were the provisions made for it.
I've scoured the web in search of a solution but so far to no avail. Any clues?
Here is the trailer:
Another pic where you can see the deck
PhysicsDude
Dallas, TX
They sell tilt trailers that use a 20 ton bottle jack.
http://www.txcustomtrailersales.com...20-hyd-tilt-car-equipment-hauler-TMwb|yW.html
As far as how exactly to mount it, you probably have to weld some brackets on.
Thumper68
Duluth MN
Put a jack on a scale and see how much force to tilt the deck, I have used the gas cylinders from a rear lift gate for that kind of thing before, real cheap at the salvage yard or 30 or so from the parts store. I usually get new ones from a truck topper dealer.
jakemac
New England
I think the solution is in your first picture.
Get another extendable screw jack and weld a pivoting mounting bracket to both the jack and deck.
kctyphoon
Jersey/Staten Island
Ditto.. and a cheap one at that.. that is unless u want a powered unit.. for that you'd need to install a battery and an electric hydraulic pump along with a long hydraulic ram. Guess you'd need to decide if your frequency of use justifies the added expense.
WittHay
Surrey, BC Canada
Is the trailer factory build or home made. If home made, I am wondering if they just used a Hi-lift or farm jack on a wood base to lift up the front. Once something is driven on the trailer it would lift up a bit and the jack would go sideways
R
rockinacummins
Wapanucka, OK
Nope, this is a Ditch Witch S7B trailer.
R
rockinacummins
Wapanucka, OK
I think this is kinda what I'm after. I'll check and see what force it takes to tilt
R
rockinacummins
Wapanucka, OK
454ragtop
Carver, MA
Any chance someone moved the axle back for some reason? It's seems pretty far back for that type of trailer.
CJM8515
Battery and a hydraulic ram would be best imho. A bottle jack would also work well but take awhile.
PBCampbell
WV
Have you contacted a dealer yet? You're going to need the lights and fenders from them anyway to make it road legal. I'd be surprised if they didn't have the lift parts available.
lilredex
Toronto
Here is a floor jack solution I saw at a local golf course.
R
rockinacummins
Wapanucka, OK
I ordered LED lights form eBay and I'm going to build custom fenders. There's no telling what a dealer would want for them
R
rockinacummins
Wapanucka, OK
This is probably the best route. I could piece together a system with a pump and cylinder from northern tool - I just didn't wanna spend the money. I will probably try the gas cylinders first to see if they can get the job done. Mainly because I still want the deck to drop after I load whatever I'm loading
fordnut85
As far back as that axle is I could see some issues with the deck dropping before the rear axles of whatever your loading got on the trailer. Personally I have used the tilt trailers that use the long ram like an engine hoist uses and they work faster than you think they would and you can control the rate and time of decent.
Sent from my Pixel using Tapatalk
Hiball
Missery
Maybe a measurement to let us know what type distance you need to cover on the front end when the trailer is in the full tilt position? I have a tilt trailer that utilizes a smaller long Jack, some roller chain/gear but it's not near as heavy as yours. When the trailer is at full tilt, does it hold or want to fall on its own? Does it balance out at a certain point?
R
rockinacummins
Wapanucka, OK
I will get a measurement (and some pics) of this.
The deck wants to fall on its own - no point where it stabilizes or balances
