WhiffySpark
- Joined
- Oct 22, 2009
- Messages
- 6,252
Someone mentioned it already; but a decent die grinder(90 degree or straight!) And some roloc discs will really change how you view an air compressor. I didn't have access to really good CFM compressors until I started working in a shop environment. Of course we have huge compressors so our tools are probably overpowered a bit. But my previous experiences was a black max compressor from the 90s most likely set up with undersized hose.
So you should still have success with a 30 or 60 gallon with properly set up hoses.
I started using a die grinder and rolocs to clean gasket mating surfaces and i'll never look back. It takes 1/5th of the time of using a gasket scraper or emery cloth, and does a better job. Also get some cut off wheels and a good arbor, and you have a compact cutting system that can go where no grinder can. Very useful for me in the rust belt for body sectional repair.
And don't forget a good air hammer with a good tip set. It's one of those tools that you have no idea how useful it is until you have it on hand.
Not recommend. Espically for intake headgaskets etc
