Shop water heater type
Speer
I am currently wiring/finishing my building and have plumbed for a bathroom. Anybody have any suggestions for a water heater?
I really don't have a preference between a tank/tankless, but I do think electric would be easier for me. If propane is MUCH better I could make it work.
I don't have a shower. I have a sink and my wife will be using the "kitchen" area to do canning.
Thanks!!!
Speer
I was looking at the small 5 or 15 gallon tanks and think that will be the way to go. I do use hot water everyday to mix up milk replacer for calves, but it's only about 2 gallons at a time.
FullRaceMerc
SoCal (SGV)
A tank will have a lower electrical load than a tankless. From your description a small tank sounds like the better choice.
redmondjp
Redmond, WA
As stated above, a small tank should do you fine - 10-15 gallon range should do the trick.
We have a 4-gallon 120V unit under our kitchen sink and it runs out of hot water when hand-washing dishes - there is enough to do the wash water, but you have to let it recover for rinsing if you want more than lukewarm water.
NUTTSGT
Northern Central Ohio
15 gallon should be fine , I have a 20 gal in mine with a full bath room and have yet to run out durning a shower .
Interesting and informative as to how much use can come from a small water heater.
A 20 gallon unit made me look at Menard's site to check pricing. I see that a 20 gal unit is about $100 more than a smaller 2.5 or 5 unit. Probably well worth the extra hundred dollars.
ddawg16
S. California
I agree with going with a tank.....and putting a timer on it....or, insulate it real well
They also make some decent POU electric units for use at the sink. I would go this route if space is an issue.
samss
Conway, AR
The Atmor 13kw tankless has been much better than I expected. It was easy to install too.
Charlie51
Bolingbrook, Illinois, USA and Michigan's Upper Pe
I use a 5 gallon electric water heater (115v) at the shop. It's mounted under a sink cabinet and I have instant hot water. Our former mobile home used a 19 gallon (115v) water heater. We never ran out of hot water unless a teenager was trying for the usual hour long shower.
ticklechicken
Florida
I went through this a few months ago and determined this tankless unit to be the best option for my shop. I just want some warm water for my sink. I ordered it, and it looks good. Still a month away from installing and testing it.
kbs2244
I go with the 5 gal electric.
Watch your use habits and maybe put a switch on it if there is long non-use periods.
