Atlas tire machine parts help
kendogg
Auburn, GA
Hey guys. I have an Atlas tire machine,a nd I'm trying to find a nylon duckhead for it. I don't need/want to spend $200 on their 'quick change' kit just to get a nylon duckhead. Has anybody found one from another machine that you can buy by itself that fits?
fordcragar
Yakima Wa.
What is the model number of you tire machine? If you do some research, it was probably made by Coates. You might be able to find what you are looking for on EBay.
markw365
What's the duckhead look like? My hunter has a simple 2 bolt job that is easy to change. I can give you the spacing on it if you want.
K
kendogg
Auburn, GA
Here's the shaft that it attaches to. I bought a Coats on on amazon, but it's tapered. That won't work.
K
kendogg
Auburn, GA
Bump, please help. Please don't make me buy damn near every duckhead I can find on Amazon lol.
K
kendogg
Auburn, GA
Can it be modified?
Maybe? Think it may be OK to enlarge that hole? What if it moves or something?
Oh, you mean the shaft. Maybe? I'm not a fabricator, idk.... I don't want to damage it though, thats probably a way more expensive part than a new duckhead.
K
kendogg
Auburn, GA
More research has shown that I should measure the shaft diameter where the duckhead mounts - 28.65mm. Lots of options on ebay for that, so I'll go that route and report back as soon as I have found an option that works.
K
kendogg
Auburn, GA
markw365
Ok, here's what I would do, I would get the hunter head and some maybe .188 or .250 tubing that would fit snug over that shaft. Then I'd cut some plate to match the hunter head, weld that to the tube, and tap or weld a nut to the tube so you can put the tube on the shaft and use a bolt as a set screw to tighten against that flat on the shaft. Of course, this requires some metal working tools, but it could easily be done.
The hunter head you'd want would be the TC-3250/3500 head, it has a flat on top and attaches with 2 8mm bolts.
