Extension ID help needed. 41-B-311-500
R
r_olson_06
SD
The two on the top are early 30s then late 30s. early has external balls, later has internal with banding at the top, 40s would be about the same as late 30s
Thanks for the post. Could you take an O.D. measurement of the round portion?
Sent from my XT1080 using Tapatalk
Rileysan
Milwaukie, Oregon
That's a Federal Stock Number, late 1930s to 1953. (The 41 is the class of the item. If you've ever heard the term Class 6 used for liquor stores on a military post, it's because that was the federal supply class for liquor. 41 was hand tools. Machines were 40. Etc. The letter is phonetic. W was wrenches. B was bars, also bits. And the number was a unique identifier. They used suffixes to expand.
Great information! I take it, the same applies to my 'S' shaped DBE I posted yesterday? I posted updated pix and info in that thread today, btw.
Brian
Yes. I didn't go into as much background about the numbering system itself on your thread, because I thought you'd see it here.
Your 'S' wrench and r_olson_06's swivel grip extension bar showing up here within days of each other with FSN's seems to imply that they're common, but you guys should know that nothing could be further from the truth.
They are rare. They show up on very few WWII tools, indicating that it was not SOP to stamp them on tools, and my research - greatly aided by a history book on the Ordnance Dept, with a whole chapter dedicated to the supply system, reinforces that. These numbers, assigned by the Treasury Department, believe it or not, which administered the Federal Standard Stock Catalog, are found in all Army and Navy technical manuals and catalogs, anything that lists tools, but are rarely found on the tools themselves. So rare that the examples to the contrary, while few in number, are very well known to all WWII collectors. And most of them are controversial (as being wartime or not) for the same reason. Some examples: DOE engineers wrenches made by a short-lived company in L.A. named Arcturus have the FSN famously forged into the shank. A few Armstrong DOE wrenches have been found with them. A shock absorber tool made by Miller. Some Hamilton toolboxes, a couple of which have shown up and been pointed out by me here on the toolbox thread, have them. The Mossberg extensions I posted upthread have been seen by others, but the unbranded 3/8-inch drive speeder (any help on ID'ing that from anyone?) and the Williams hinge handle are the only ones I have ever seen of those. EDIT: In contrast, think about the hundreds and hundreds of popular wartime tools made by Plomb, Snap-On, etc, that you've seen, in person or here or AA etc, almost all without FSN's, and you'll have the context for tools with them.
Ironically, most of the examples are considered post-war. Ironic, because a commission was established shortly after the war was over, due to all the supply issue and competing stock numbering systems, and the 11-digit National Stock Number was eventually established (1953).
snapmom
Florida
A MS0-6118173 with a 1941 date code.
Interesting, snapmom. I'm not sure if that's in reply to my post, but we do find plenty of other stock numbers on wartime tools. NAF-###, for example, a Navy Aviation stock number, seen on toolboxes and wrenches (including Plomb DBE's, and Diamond Calk auto wrenches, just to name a few examples). WF- (USAAF), of course, and Ordnance Dept "TAXI" numbers, etc. But not many Federal Stock Numbers (41-x-xxxx).
I don't know what MSO-6118173 is, but it's not an FSN.
It's not Navy, USAAF, QMC, ORD, Signal Corps or Corps of Eng either, as far as I know. Has anyone ever tried identifying it for you?
snapmom
Florida
No, I assumed it was military, does not have the snap on name, and usually if it was made for industrial, it would have a S to start the model number. Also it has a 41 code, and no finish. I have seen a couple of them.
Here are a few of the FSN marked tools I've collected. Lugz has seen most of them. The last two pictures are of a very rare FSN marked crossbar that Tin Medic found.:eyecrazy:
-DonIMG_5890.JPGIMG_5891.jpgIMG_5892.JPGIMG_5897.JPGIMG_5898.jpgIMG_5900.jpgIMG_5901.jpg
Lugz,
That rare crossbar ended up traded to a collector in Tennessee. I was pretty disappointed that Tin never found another. Here are a few more FSN marked items.
-DonIMG_5905.jpgIMG_5906.jpgIMG_5907.JPGIMG_5910.jpgIMG_5911.JPGIMG_5915.JPGIMG_5916.JPG
