This is not another debate of the merits of under slab insulation
I know I'm doing it - 1.5" Pink Board.
My garage is 28x42 - 3 car semi-attached with living space above. I'm curious what techniques you all have found best/most efficient for foam at the edges. I have 8" trench block and 3 courses of 6" block on top of that all the way around. Wondering the best way to try to isolate the slab from the cold exterior walls. I have 2" foam around inside of trench block for about half of the garage - and 2" foam around outside of trench block on other half (long story - don't ask....). I want the slab to rest on the 2" ledge (difference between 6 and 8" block) I have around inside of foundation - but would like to insulate it. Thought about putting 24" tall 1/2" pink board on the interior foundation walls and then putting FRP all the way around 4' up to facilitate washing the garage out? Also thought about putting 1/2" foam on top of the 2" ledge as I don't think I want 1.5" foam on top of my ledge under the slab as I want a solid bearing point for the slab on the foundation.
Also, do you recommend poly vapor barrier when using foam?
Techniques for foam at Garage Door Openings (3) and Passage Door Opening (2)?
I don't plan this to be a working garage - just daily driver parking for my wife, kids and I. That said there is finished space above, so I want to keep it at say 45-50 in the winter. I'm thinking a couple small propane fired radiant heaters should do the trick? Tell me I'm ok not putting radiant in the slab? I don't want to regret it later that I didn't put the Pex in - LOL. I plan to live here another 30 years.....
Thanks for the input!
