subarub4
I was wondering with the different tooth versions is the torque number the same? I just wonder if I risk breaking a ratchet trying to get this bolt off.
IMO, the anvil should break before the teeth...
on a proper good ratchet yes it likely will.
What tends happen on low and midrange stuff is the teeth cam out either due to tooth edges failing or general alignment and play allow it to happen before reach torque limit of drive square anvil, also most have less teeth engagement and not as good teeth meshing as some better made examples . My HF 3/8 been warranted once due to cam out from using it hard, was pushing it pretty hard though.
Had same happen on an extendable 1/4 72T taiwan but again pushed hard .
Got fair few taiwan ratchets and snapon and in general they all hold up well regardless of tooth count, some of the newer off brand taiwan or china stuff at 90T and up not the best but the 72T from better factories or with usable warranty gives you pretty good ratchet generally .
So what should I do? HF is a little far from me (my car is down which is why I'm asking here) I know on Amazon they have a 30" breaker bar, I don't know what home depot has in stores.. my current breaker bar is 19"
I gotta get that front oxygen sensor in
If you do any real wrenching at all, then you need a long handle 1/2" ratchet...and preferably a flex head with a long handle. The Pittsburgh Pro's are a smoking deal when you weigh it all out. To get slightly better, you pretty much have to spend double the money. To get a good US made long/flex 1/2" ratchet, you're going to start at around $75, and can easily spend twice that.
But the first time you need it, suddenly $75 doesn't seem like it was all that much money!
Unless you have a torch take it to a shop. If you snapped a ratchet it’s probably seized and will most likely pull threads out
I have a torch it's propane it might be better to use Mapp gas on it however.. It's on a part of the exhaust manifold that I can replace in a section but who knows what the dealer would charge..
to be fair the ratchet was only 3/8" not something normally I would use on something that stuck the combination of not having a 19mm 1/2" socket nor a 1/2" ratchet forced me to downgrade.
Wont get hot enough.
5300 °F isn't hot enough?
That’s an oxy torch. Not a handheld blue can propane torch. Big difference.
You want it growing cherry red. If it’s that stuck it usually pulls the threads out anyway
They make a yellow hand held propane torch, mapp gas.
3700 degrees seems plenty hot to me, I've used both the blue and yellow cans with great luck on cars.
https://www.fleetfarm.com/detail/be...nVmse2lFa7i4BTLSq6I8MMimZKP48oxBoC8AYQAvD_BwE
Some do, some don't, varies from brand to brand.I always wondered about flex heads does the flex head lock into place or say if you are using it can it flex out of line when say tightening a bolt or whatever?
It’ll work here and there but nothing compares to a real torch.
Induction heater works just as well as an oxy-acetylene torch for getting bolts cherry red. Safer too.
Modern fine-tooth ratchets are superior in strength to coarser tooth ones. You'll inevitably shear off the square drive on a 3/8" ratchet somewhere between 300 and 350 lb-ft, though.
heat it with a torch and spray some penetrant on it.
I've had good luck with an impact gun on O2 sensors. Go easy, though. Give it a brap or two and try a breaker bar. Repeat.
I'm going to get a 3/4" breaker bar
Also which induction heater is this?
https://www.amazon.com/dp/B008XN9HO6/?tag=atomicindus08-20
or
https://www.amazon.com/dp/B00ATSL7VE/?tag=atomicindus08-20
They're an expensive initial investment but, use it just a few times and it's paid for itself. Also cheaper in the long run than an oxy-acetylene torch due to not having to buy gas.
Well the only thing is the car is parked without a area for power so that's the end of that..
