zakmartin
What do you use to get lube or oil in a ball-on-spring lube point fitting that is flush with the surface of a tool, like you see on angle die grinders or the oil plug on old Craftsman V-series ratchet wrenches?
Also, what kind of lube do you use in your pneumatic angle die grinders? I'm assuming that since it runs at such high RPMs, you'd want to use something light like Liquid Wrench All-Purpose Lubricating oil. 3-in-1 seems a bit too thick for this kind of application, but that's just a guess. I tried pushing the ball bearing down with a pick and spraying oil in there through a straw with an aerosol can of Liquid Wrench, and oil just sprayed everywhere (it's tough to do this with a rag on top, since you can't see if the ball bearing is depressed enough for the oil to get in.)
Finally, how often do you lube the angle section on your angle die grinder air tool? I add a few drops of air tool oil at the air inlet every time I use my tools, but the extra lube point on my die grinder has me scratching my head.
Thanks for any help you can offer.
