Cobalt step drill bit suggestions?
Robertdeuce
I was wondering if someone could recommend a good cobalt step drill bit? Who makes the best one?
Kaizen
New England
Harbor freight makes a great one. Three in a package. Lasts a long time. Fraction of brand name ones. Used one on eighth inch steel drilling over forty holes before it started to dull
tarbellb
Oregon
Best bang for the buck, HF. But you do get nicer, longer lasting bits if you spend more on a USA made model like Irwin, Lennox, Milwaukee, Norseman, etc...
Maybe check out Drill Hog on Ebay, USA made and warranty. Ive had OK luck with them...
Olafur
Iceland
I have bought few sets on ebay from Hong Kong sellers. They seem to do exactly the same thing as something you pay 10-20 times as much for. Stainless steel; no problem.
gregpack
I too have bought the cheapies and had surprisingly good luck . I've found that if I use firm pressure and super slow speed they last a long time, even in stainless. I use a cordless drill on the slowest speed setting it has. Running them at a faster speed burns them up quick though.
R
Robertdeuce
Do you have a link to the one you used?
I'm drilling 1" holes into 11 gauge steel.
tarbellb
Oregon
Most step bits are double fluted, including the HF models.
Your best bet for 11g SS is going to buy a step bit that maxes out at 1", drill a 3/16" pilot hole first, then blast through with the final step.
I have drilled 100's of 1" holes through 11g and thicker doing this method, fast, easy, all with a cordless drill.
And the HF bits dull quicker and are prone to breaking at the hex drive shaft, I have broken a handful but never broken a standard 3 sided shaft.
R
Robertdeuce
The material I'm drilling into is 1/8" hot rolled steel. Is cobalt only for stainless steel? Thanks guys
Kaizen
New England
Just search harbor freight step bit. There is a three piece that goes up to 3/4 and a two piece that has one above one inch. I never bought one before due to the expensive prices I've seen. Took a chance on these and they are awesome. If I have a lot to drill I will use a pilot but to make the hole before using these. I've been burned by the shavings more then once. Also you don't break your arm like with a half inch or bigger drill bit
