So I ended up firing the guy building our shop office. He was trying to use piece together rafters, and he was not using headers on load bearing walls. The headers he did build were incorrect. The top plates were just pieced together and did not tie the corner joints together. I've started to repair this myself, but I'm far from a carpenter. Any pointers would be greatly appreciated.
In this first pic you can see the fabricated ceiling joist, even though I had 2x12x16 laying in the floor for him to use.
Untitled by Brett Sparks, on Flickr
In this second pic you can see the lack of a proper header and rim joists
In the third pic you can see where I have removed his ceiling joist and started fresh after adding a third top plate to tie all the walls together.
last pic show the rim joist with temporary braces to hold it in place. I still have to correct the door header and nogging.
Untitled by Brett Sparks, on FlickrIn this second pic you can see the lack of a proper header and rim joists
Untitled by Brett Sparks, on FlickrIn the third pic you can see where I have removed his ceiling joist and started fresh after adding a third top plate to tie all the walls together.
Untitled by Brett Sparks, on Flickrlast pic show the rim joist with temporary braces to hold it in place. I still have to correct the door header and nogging.
