Page 1 updated with lightup.com 10% off codes.
Just ordered bulbs and can confirm that this 10% off coupon code does work.
Dave.
JoeMayo - At 11ft you'll just need more, or try to find fixtures between 6500 & 10000 lumens.
Lumegen the 4ft fixture with 2 t8 leds that are still on the first page?Lumens per $ is still best will the LumeGen strip light. Hard to justify the additional cost for higher output fixtures at 11ft.
Here's the Dialux PDF report (link)
Yes.Lumegen the 4ft fixture with 2 t8 leds that are still on the first page?
From 1000BulbsHi, I’m sorry if I missed this, but what are you using for the actual bulbs?
Well, my Fixtures have ArrivedFrom 1000Bulbs
Super fast Delivery Time....Dallas to Houston is only a few hundred miles.....
Took a few picks of the new arrivals.
Each of the 4 big boxes had 6 fixtures (in their own boxes) centered with Peanut cushioning around the outside for protection.
Great Job of Protecting the Fixtures. the outer box would have had to take some serious thrashing to damage the inner boxes and fixtures.
Will post more when I install these in a few weeks....
What you are seeking, I think, is a conduit knockout on the back of the housing. I don't think I've ever seen a surface mount housing without one. I can almost see it under the lamp holder in this pic from cory58 post 835 (link):Does anyone know if there are underside tabs for the fixtures sticked here? LSS2XT8USE4803
I see the side tabs in the images, but I can't find a shot of the underside to see if I can run cabling that way. So I can do it through the sheetrock instead of off the side, for a cleaner install.
Plantonic Solid, Thanks for all the information you have shared on this thread. I have done quite a bit of reading but I wanted to see what you thought about my project. I have a very simple small two car garage. It measures 21'x19'. There is a water heater closet in the front left of the garage that measures 28"x67". The overall ceiling height is 8'. I want to install hardwired LED lighting fixtures. Can you recommend placement and qty of lights? There are no windows or exterior doors other than the garage door.
In another of your post you recommend the following. Is this what you would recommend for this project? Thank so much for your help.
--22W LumeGen 4ft single end bypass tube
--Maxlite LSS2XT8USE4803 75303 2 Lamp T8 LED Tube Ready 4 ft Linear Utility Strip Light Fixture Pre-Wired
The page 1 LumeGen lamp was available in 5000K, but it doesn't show as a pull down option. I'd call the distributor for 5000K as their site could be wrong. 6000K is hard. Not many asking for it thus supply reflects demand.Is there a lumgen bulb with that brightness at 5000 or 6000k?
I haven't been able to find anything in 6000k higher than like 2300 lumens. Am I searching in the wrong places?
Also should you go with 4000k or 5000k?So, are the bulbs from light up in the first thread available in 4000k and 5000k? Or just 3000k and 4000k?
Ok will do. I am getting real close to placing my order for fixture and bulbs. Thankspointer80 - 4000K or 5000K CCT is a personal preference thing. To each his own. If you go to the LumeGen spec sheet, they don't show 3000K as an option, yet the Lightup site only shows 3000K and 4000K as selectable options. If you want 5000K I'd call Lightup and find out if their site is just wrong. If you want 5000K and Lightup doesn't have them, I'd go with the lamps I found from HD in post #989 above. Then the question becomes - are you willing to spend an extra $3 per bulb for 5000K? If you do call Lightup, please post your findings.
I did a little searching and this 5000K 2400lm 20W Euri Lighting LED Hybrid ET8-1150H-20 (link) is a pretty good deal @ $10 ea. from HomeDepot (link).
Well, I got my 50 bulbs a few days ago. I guess I am part of the back order problem
Sivart321 - This should be in its own thread. That said, I can't tell if the off-center support beam and angled front interfere with a fully recessed fixture install. A low profile surface mount custom frame for 1x4 edge lit panels would solve the support beam interference. As far as the angled front is concerned, those fixtures just have to be pulled back, which I don't see as a major lighting issue.
