Concrete contractor is setting up and pouring my floor in the morning, I have not had an opportunity to discuss specifics about reinforcement and mix. I want this done right, these guys are good but what you don't ask for you don't get. 4" pour, rebar size and spacing?? Im leaning toward 5000 psi mix. They are going to tell me 4000 is fine and 5000 is overkill. The garage is detached, on footers, stem walls with ledge to carry the floor. Stem walls are insulated inside with 2" foam down to footers. Frost depth in my area (MN) is 42". No in floor heat. Planning to pour over a 6 mil poly vapor barrier. Soil has been compacted. Building will be heated intermittently with a unit heater. Suggestions welcome.
