drivesitfar
Lump: early to late 1940's cause i'm pretty sure that is a PAT PEND cast in that big wilton. There is a Wilton date stamp thread I started over in Vintage tools that you are welcome to look at if you have any time and here's the link so you don't have to search.
i think the 6 inch wide jaw was the biggest one that Wilton made with that design too so although it's been rode pretty hard it's not a common vise. it looks to be ok as far as the bones cause i don't see any cracks under it's jaws which is fairly common for a Wilton used that hard. it's missing both swivel pins which isn't a big deal cause some of those older Wilton actually came with acorn nuts.
as is the value is probably in the 2 benjamin range and cleaned up maybe double that is my guess if that helps you.
CA: all those Gerts boxes yours? very nice!!
Asphalt: we don't see that Record model very often or at all. i'm guessing you are from across the pond so you might put in your general location in your profile and while you are in there maybe click on Avatar and put in your favorite picture that will show up under your name sort of like an identifier. welcome to the group and nice find!!
and you are in luck, I still have half can of Regal Red left which I will send your way should need arises
