First time braising feedback?
Kaizen
New England
Is that even how it's spelled? Icy acetylene braised two copper fittings. Seems sold but looks horrible. Any pointers or is this just how it looks till you clean it up? I had dust of some sort fall out when I turned it over. What was that?
fnieto
Tucson,Arizona
Brazing if you used silver or brazing rod.
Soldering if you used solder.
You got it way too hot. You only need to heat enough to flow solder keeping the heat on the fitting.
K
Kaizen
New England
I should have said what I was doing before. I'm making something from a 1inch cap and coupling. No pipe. It's going to be too hot to use solder so I braized it. I'm a pro at plumbing soldering. Still think I got it too hot? I did use rod
sixty4
CT
Pretty much how they come out. With brazing you really need to cook the joint to cherry red to get brazing rod to flow. Not bad looking at all. The soot that came out is normal with out a nitrogen trickle.
K
Kaizen
New England
Thanks. That's what I did but both pieces were Cheryl red. Will use a smaller tip next time
matt_i
SE Michigan
Could also use 56% silver solder, its high temp stuff as well (can't recall exact but ~1000F), I find it "wicks" better than the classic bronze braze which tends to wet all over, prone to dripping and running and not really jump into a fit.
K
Kaizen
New England
Follow up question. How the heck do I hold two cylinders of copper together to braize? my clamps tend to pull it off center. I also want to braize a steel bolt on the bottom of the copper. Sorry I'm used to a mig where I just tack it in place before working on it. again these are **** joints not pipe inside of a fitting which holds itself
Oregon rock crusher
West of Salem
Sometimes something like this electrical strut or a similar homemade jig can be used to align tubing for but welding / brazing. Gives access to four sides without having to unclamp.
mike13u
S.Florida
You clamp them in a V-block or a piece of angle iron so that they rest evenly and flatly in the V
