I have a harbor freight 29gallon compressor and trying to quiet it down.
So I did a few things this weekend
2 3/4” foam pads under it
1 foam pad against the wall where it sits
2 hockey pucks for feet. 4 total on one end
Put 2 larger rubber wheels on the other. They were 8” and I changed them to 10”
Cnc plasma cut a flange and welded on a 90* fitting and put on a solberg filter. Also tried adding a hose to remote mount the filter.
Seems most the noise is coming from the motor, pulley and not the intake.
After all of this..the sound is the same, maybe 1 to 1.5 dB max.
So originally it was 86db before any mods. Put on the filter and out of the blue the head gasket failed. Put on a new one, added oil and then it’s 88-89db. Now it’s 87-88db after all the mods
Tried a larger air silencer and it only got louder.
Was thinking about adding strips of dynatmat to half of the tank that faces the wall. Would that help or anyone else have any recommendations ?
