Well figured I’d post on my next pre snow project lol
I have an 84” wide 3ph snowblower and I went it to be run with my John Deere 333d skid Steer.
So skid steer hydraulic specs are 3450 psi at 25gpm.
I’m going it’s a baseline of 540 is what the pto turned the blower.
So I calculated needing roughly an 8.whatever cubic inch georolor motor. Not sure if I just want to spin the gear box and leave the Chain nd everything which I think I should then install some sort of overrun clutch, or remove and try mount 2diffferent motors. Would also like a block to have my other electric aux buttons control Shute angle and direction. Looking for any hydraulic advice or any input. Got an idea of how I wanna do it but always open to ideas.
Sent from my iPad using Tapatalk Pro
Pulled gear box off to check it out and replace seals.
The front auger turns about 1 for every 3 motor rpm. So at 540 from the motor about 180 on the auger.
