frankd
So I recently converted from an extension spring setup to a torsion spring. The next step is to install the liftmaster 8500 which I recently purchased. After reading several threads on this board as well as some service bulletins from Liftmaster, it look I need to do one of, or all of 3 things:
- Install pusher springs
- Adjust the horizontal track so that there is some "slope" to it... so under normal gravity the door wants to roll down the tracks and close itself
- Reduce tension on the springs so that the door has a bit of weight on it coming down.
Right now, in the open position, the door stays there and does not come down by itself at all. So with the opener installed, when I close the door I'm assuming it wont come down and it'll trip the cable tension switch.
I'd like to solve the issue by just putting some slope in the horizontal track. I'm thinking/hoping that only a couple of inches would do it. Can I just loosen the hardware that secures the horizontal track, raise it up 2-3 inches and re-attach it? I don't want to have to mess with the whole radius and get new tracks.
Door is 16' wide, 6.6" high. about 210 lbs. 12" radius.
Any input would be appreciated.
