Ok I put up lights and now hanging osb on walls. Who else is using osb and how did you paint it? Spray or roller? What colors look best on osb? I was thinking a lite gray? I don't want a dark color that's for sure.
Thoughts???
Thoughts???
You put anything on seams? Thanks for pic!
Not much work at all, and quite inexpensive.92nsx, looks like you put it on rough side out, rough side takes a lot more paint.
Someone else mentioned putting as coat or two of drywall mud that seems like a lot of work.
Which ever method you choose, you could make it much easier by prepping and priming on the ground before you hang it.
If you intend to condition tbe space you'll want to caulk the seams to stop air movement.
