My 2 Car 18x29 Detail Studio
A
AndrewBigA
LONG ISLAND, NY
Re: my 17x29 detail shop BIG "A" DETAILING queens ny
the shop has been very busy so things are going slower then expected. at least its for good reasons =) we are finished installing the insulation. we have only 1/3 of the foam boards installed. there are alot of pics so ill try to put them all in order.
A
AndrewBigA
LONG ISLAND, NY
insulation on half the shop is done. shop lights & other things were taken down to start installing the foam boards.
went with 1/2" foam 4ft X 8ft boards with some reflective heat
foil film on one side. i think thats what the silver stuff is.
im going to need about 15 or16 total boards to cover the entire ceiling.
peeling back the film on one side to expose fresh white foam
some primer just to do a test board
some yellow paint
the paint reflection off the yellow background will allow me to see deeper into the paint for defects & scratches for when i do paint restoration projects. the white background is good but can hide some scratches & other paint imperfections i need to see in order to do a flawless job for special jobs we have in the shop.
johnny on the paint roller
travisd
Westminster, MD
So... given the big warning printed on it about being Combustible, are you not going to cover it with something a litle more fire resistant? Would **** for a small "event" (like a bad light fixture) to become a total loss due to catching the EPS foam on fire...
freebeer
Yeah, I was thinking the same thing when I saw the paint come out :shocking: That place would go up like a wicker basket. Not to mention your insurance co. would probably deny any claims.
A
AndrewBigA
LONG ISLAND, NY
whats the difference having the wood exposed without insulation & foam or having insulation and then foam exposed? everything can catch fire. i will leave the ceiling with the foam for now. do you have any suggestions besides sheet rock?
ZRX61
Solar Blight Valley, SoCal
This is going to end badly... I would imagine you're violating local building codes at the very least. Have a fireman come by & give you some advice... before the city shut you down.
*if* you do have a fire, the cyanide gases from the burning styrofoam will kill you before you reach the door..
....& you might want to also read the MSDSs for the products you use without a mask.
A
AndrewBigA
LONG ISLAND, NY
can you suggest something else other than sheetrock?
freebeer
Big difference. take a lighter to the wood for a few seconds and then to a piece of that foam and you will see the difference. The wood will scar, the foam will light up.
It's your shop so do whatever you want but what do you have against sheetrock?
A
AndrewBigA
LONG ISLAND, NY
never hung sheetrock before & dont want to pay anyone to do the work for me when i can do it all myself with the help of my 2 workers. i guess im going to eventually cover the foam with some wood. thanks for all the advice, thats why im on here =)
i guess i wont be priming & painting the foam, ill use that money to buy some thin 4 X 8 wood boards.
thanks!
A
AndrewBigA
LONG ISLAND, NY
It's not rocket science, 3 of you could sheet that ceiling in a few hours.
im not putting up sheet rock, ill do wood thanks
did i waste my time with the foam boards or should i continue to put them up and then finish with ply wood?
freebeer
never hung it before & not wasting money hiring someone to install it for me
Sheetrock is no harder to hang than that foam. Just a little heavier. Two of you can do it easy. Just buy a cheapo sheetrock gun and give it a go. You might break a piece or two but so what. It's a way better job than the foam.
Edit: better than wood too. Also wood probably won't meet city code either.
A
AndrewBigA
LONG ISLAND, NY
not hanging sheet rockfor the last time ill do ply wood, thanks for all your advice. im on a budget & xmas is comming soon and then my gf bday is on dec 29th =(
freebeer
Like I said in an earlier post. It's your shop, do whatever you want. but since you mentioned you are on a budget, rock is about half the cost of plywood and easier to work with.
wrigh003
Birmingham, AL
I can see not wanting to go to the mess/trouble of installing sheetrock, what with all the dust it will create (dust that could end up in a customer's paint one day). That said, though, I would still put it up.
Alternatively, you could use hardipanel or some other type of paneling. Sheetrock will be cheaper, though, and if the dust from sanding is what you're trying to avoid, you could cover the seams with furring strips. Leave the foam up there, just use long screws. You'll have the most efficient ceiling for miles around.
A
AndrewBigA
LONG ISLAND, NY
just got back from home depot and sheet rock is a little less than $6 for a 4x8 piece. i just spoke with a friend of mine & after thinking it over, ill sheetrock everything after new years but first i will finish the foam. thanks everyoen for your advice. i might as well not be lasy & spend the little extra time & money to be a little safer in my shop =) thanks again for all your help everyone.
im giving into all the advice on the board & after speaking with a freind of mine this morning. ill finish with the foam boards but after new years, xmas & my gf bday i wil sheetrock everything.
btwy, we dont paint in the shop we just do detailing. i wasnt concerned with the dust of installing the sheetrock. i just thought it was more of a pain in the *** to install & it turns out i was completely wrong.
updates comming today...
A
AndrewBigA
LONG ISLAND, NY
painted a sheet yellow to make sure i was set on using yellow for the ceiling.
seams will be sealed off even though ill be sheetrocking everything
foam boards is about 1/3 done
A
AndrewBigA
LONG ISLAND, NY
first half is insulated & foam boarded up
some more insulation rolls for the other half of the garage
rburke65
Canfield, Ohio
Your place is looking better every time I open this site up!
A
AndrewBigA
LONG ISLAND, NY
thank you. we have much more work left then i had thought in the begining but thats ok. after new years the sheetrocking will be going up along with 4 more 8ft shop light fixtures & possibly another 2 4ft shop light fixtures. i need it to be very bright in here because i use the garage for detailing cars. i need to see deep into the paint for imperfections etc...
timberseal
Another option for the ceiling would be the steel sheeting. It comes in 38" x 16' panels and is prefinished and makes for a great ceiling. 36" 's of the panel shows while the other 2" is the overlap. Secure it will pole barn screws and your done. It's about $33 a sheet though but after factoring in the cost of primer and paint it was the same as if I would have put up many other materials.
A
AndrewBigA
LONG ISLAND, NY
can you send me a link to this product? the ceiling has to be yellow. yellow gives me the best view of the paint on the carswhen im detailing them. i know it sounds funnny but thats what i need =) its difficult to spot imperfections against a white background & also on a really dark one. yellow is the perfect color for looking deep into the paint.
timberseal
You can see it on the ceiling of my garage here. This product is called ProRib and comes in alot of different colors albiet some are special order. ANY place that puts up pole barns or shops around you can get it for you Im sure.
Some major's around here would be FBI buildings, Morton and Cleary. They all should have an office near you as well.
A
AndrewBigA
LONG ISLAND, NY
that looks pretty cool but the design of the material is not good for seeing into the paint. i need a completely flat ceiling or the images (scratches) wont show up right when i look into the paint.
A
AndrewBigA
LONG ISLAND, NY
my friend paulie is comming tonight to prep the ceiling for sheet rock. some of the pieces of wood between the beams are not level with the bottom of the beam making an uneven surface to lay the sheetrock over. im not a quitter but i will **** it up this time. hes also going to notch the bottom of the beams so the bx cable isnt in the way for when the sheetrock is installed. only bad thing is i now owe him a in n out detail on his fathers mercedes sl. i guess this is a good deal, if i finish the job myself im taking a chance of burning the place down lol.
Vettegator
Long Island, NY
thanks, where on long island are you from? need a detail? :)
Im out in Eastern Suffolk. I usually do my own detailing, but who knows, if I need a detail and am too lazy to do it over the winter, I will definitely give you a shot!!
A
AndrewBigA
LONG ISLAND, NY
you got it. let me know if you need anything. ill be posting up pics from the work my friend paulie did last night. he set up my ceiling for sheetrock & took down all those foam panels. he showed me with a torck how fast that **** lights on fire & then he torched a small piece of sheetrock to show me the difference.
cyclopsblown34
Russellville, Missouri
I thought the foam board went behind the sheetrock. I could quite easily be wrong though. Excellent work Andrew. Thanks for the tip about the yellow paint. Are you talking Corvette yellow or just a light yellow? I'm wondering because I just might repaint the ceiling in the booth/detail room.
Thanks for the excellent thread,
Chip.
A
AndrewBigA
LONG ISLAND, NY
Chip.
no my stupid *** was going to finish off with the foam boards exposed primed & painted =/ thanks to some members on here & to my friend paulie who does this stuff for a living, i will sheet rock just not in a rush to get it finished. i hate having things started but not finished. im going to be installing a few more lights since the con ed bill is so low. after extra lights are installed & a few more outlets added in, then ill do the sheetrocking. im looking for someone to do it for me for a good price. one of my workers friends is supposed to stop by here in a few days to price everything out.
i need my shop to look really nice at all times. it makes it easier to sell those $250,$350,$450 paint restoration jobs.
and yes the yellow ceiling will be the best for looking deep into the paint for defects. i never seen anyone do this before but im not worried about being the first! lol
best part about paulie helping me out last night was me smoking pot then ordering spanish food from mr pollo II while sittign at my desk haha!
cyclopsblown34
Andrew, I'd probably omit the one comment about herbal medicine seeins how all your info is on here. You never know what kind of loons are reading posts and just want to stir the pot.
