14 Piece Hydraulic Punch Driver Kit
bczygan
DETROIT! Arsenal of Scrappers
I know Greenlee is the standard for these. But at approx. $1,500.00, they are out of my reach.
I have a chance to get the Harbor Freight version NIB for $50. Price at HF is $95 less 20% coupon.
Anyone use that one? Comments?
Bill
https://www.harborfreight.com/hydraulic-punch-driver-kit-96718.html
Bill
ttpete
Dearborn, MI
If that uses the same thread sizes as the Greenlee punches, it would come in handy for me because I have a complete set of punches from 1/2" to 3-1/8"
Bottlecapdigger
Ontario
I haven't used anything other than the greenlee. But looking at the pic you posted it looks pretty decent. For the cost I might get one myself. BCD.
bczygan
Got it home an punched some holes in aluminum.
The Greenlee set has 1/2" and this one doesn't.
Ended up costing $52 because he didn't have a $10 to change a $20.
Still good in my book.
Bill
pi_guy
N/A
It does not. I wished it did.
The HF one cuts one hole then next cut starts to distort the material your cutting.
ADSR
I have that one, but I haven't used it. I can't remember the members name, but the dude in the dimple die thread has that one and it looks like it works very well.
ADSR
looks good. When I get around to using mine, I think i'll be more than pleased.
BDAZSVT
I have one and also use it for the dimple dies. I have no problems with it.
ADSR
You can also add the exhaust pipe expander from HF
Strouty
Southern Maine
I would be amazed if that held together to actually expand exhaust pipe. Those tools are designed to make a pipe that has been distorted, round again, not to stretch the pipe. Lisle makes a nice set that actually will do that, then the hydraulic tool is great.
ADSR
Lots of youtube vids on it, it looks like it works well. I have the lisle set and the punch set, but haven't used it yet. I do have a job coming up tho.
dv8customs
East Texas
I have the punch set, don't use it a lot but never had an issue. The hand pump works great with my dimple dies though.
bczygan
Here's some additional information.
The HF kit does not include a punch and die for the 1/2" conduit.
And the Greenlee punch and die for that takes a 3/8" draw bolt or draw stud.
I'm looking at a 7235BB Slug-Buster set from Greenlee which has, of course, draw bolts, not draw studs like the HF hydraulic unit uses. The Slug-Buster set has the 3/8" and 3/4" draw bolts. The 1/2" one is the one that takes the 3/8" bolt. I can use that as is, with a wrench, or get a 3/8 draw stud for it and use it with my hydraulic set. The other 3 sizes use a 3/4-16 thread in the punch and draw bolt. Luckily that is the size my set uses for the draw stud, so I'm good to go there.
So, except for the 1/2", the HF and Greenlee items are compatible.
Everyone follow?
I'll be testing this tonight.
Bill
machine_punk
Napa Valley, California
What pump and what pressure you running the ram at?
I use the HF pipe-sized punches. My main use for them is to create the holes for the SWAG Offroad pipe-sized dimple dies.
The pump is readily available online for about $225 USD. Says it is rated for 10,000 PSI. If you have a hose made for the pump, make sure you ask for the 'jack rated' hose, which will go up to 10,000 PSI.
I haven't had any trouble with this set and I've punched dozens of holes in aluminum and steel sheet.
This is a bracket I made for my garage-door opener. Then, a wine rack in the style I usually build (aluminum sheet and rivets, using the same techniques for building aeroplanes).
Kev
bczygan
Harbor Freight 60575 is the manual/screw driven set I also bought, $24.99. It has the 1/2" die.
Bill
I checked that set out yesterday as well.
The 1/2" punch and die takes a 7/16" draw bolt or 7/16 draw stud if you want to use it with the hydraulic unit.
So you can either get a 7/16 draw stud and 1/2" punch and die or buy the manual set and use the 1/2" punch and die with the hydraulic sets 7/16 draw stud.
Note that the punches in the HF sets produce a "wrinkled" one piece slug. The Greenlee ones split the slug for easier removal. But I had no trouble removing the full slugs.
Other look-alike hydraulic sets, similar to the HF may include the 1/2" punch and die.
The 1/2" will be used the most because it can be used to make the starter hole for the larger sizes, and it is the most used size for electrical.
Billl
machine_punk
For the starter hole, which is 3/4" (19mm), I use the new "impact-ready hole saws." They have finer teeth, which makes them great for sheet metal. They have a spring on the pilot bit, which spits out the slug as you punch through the material. Not too expensive (about $11 USD). They've lasted a long time for me. Available from most major brands, such as DeWalt or Bosch. I haven't seen a significant difference in quality by brand...they are all good.
Available on Amazon. Search D180012IR for the DeWalt version, HTW34 for the Bosch version.
Kev
Rtw5150
For the starter hole (3/4"), I use the new "impact-ready hole saws." They have finer teeth, which makes them great for sheet metal. They have a spring on the pilot bit, which spits out the slug as you punch through the material. Not too expensive (about $11 USD). They've lasted a long time for me. Available from most major brands, such as DeWalt or Bosch. I haven't seen a significant difference in quality by brand...they are all good.
Kev
I use an actual 3/4" hole saw, not 3/4 trade size (1-1/8") that way there is no slop for the draw stud so you don't have to waste time lining it up. Just make sure you lay your holes out right :)
I also have the HF punch that I picked up one day when the seal on my Greenlee tool a ****. I never used the dies since I just used the Greenlee slug busters but the punch worked out great.
