Double Deep Well Socket Tray
Farmall450
Marengo, Illinois
Does anyone know of a tray that has 2 rows of deepwell pegs, as opposed to a deep and a shallow?
It is for a SAE and metric set of deep impact sockets. I'm ok with the numbers being off for one. I don't want rails mainly because they tip.
Fedwrench
Valley of the sun
Trays ****!!
However, snap on makes a three row tray for shallow, semi deep, and deep sockets.
You could also get the Ernst three rail tray and configure to your needs.
JimNC
NC
Who is the guy that makes the anodized aluminum trays with pegs, they work for 2 rows of deep. Like the product, can’t remember the name.
Al Borland
There are trays with short posts that are also magnetic. the posts are not marked for size.
Two Door
Houston, TX - USA
Kobalt makes combination SAE/MM trays, although the pegs are short. They come in either 1/2" only, or a set of 1/4, 3/8 and 1/2. Google Kobalt Socket Tray SAE/MM.
F
Farmall450
Marengo, Illinois
I was thinking those, but figured they'd be too expensive. On closer inspection for the universal 18 socket one it's only $15...not too bad. That'll do the trick if I can sort down to 9 of each size. :beer:
F
Farmall450
Marengo, Illinois
That'll be my backup, if the westling doesn't come through. More pegs but most will probably be too close on the lower end.
F
Farmall450
Marengo, Illinois
So unfortunately the Westling holds 9 - and I need 10.
Additionally the Kobalt hits a lot of smaller sizes and might not work out. Any other suggestions on 'universal' 1/2 ones? Preferably 20, in 2 rows of 10. Thanks,
